while driving yesterday, car had total power loss.. cranking it thereafter resulted in flat battery.. so chucked in a new battery but cannot hear the usual fuel pump whine and prime in the boot.. have checked all fuses..
opened fuel pump cover with ign on, both fuel lines were easy to squeeze.. im assuming if it was being primed by the pump, one shud be hard and filled with fuel.. what else can i check.. any suggestions welcome..
btw does anyone have a spare gtr fuel pump i can buy/borrow.. and recommend a decent towing company in western syd
https://www.sau.com.au/forums/topic/205978-unable-to-start-car-help/
you could pull the fuel line at the fuel rail while the car is off, hold it in to a bucket, then turn the key to start and see if fuel gets pumped out.
if it does, fuel pump is working and problem maybe in the injectors or ecu to tell the injectors to open/close etc.
But since you can't hear the pump prime, I'd suggest it's probably a problem there.
You could go old skool and have a mate crank the car over while you smack the fuel tank with a pipe to see if you can jolt the pump to start.
yeah figured the usual noisy priming points to the fuel pump.. tried smacking by hand the tank from the bottom and around the fuel pump cover hoping it wud do something..
the car did a power run for 1st time few days ago.. im thinking it might have sped up its impending death.. judging by the fuel pump cover, car still has stock pump..
maybe i was doing something wrong in the dark last, but couldnt get a reading from +ve wire on the 2pin connector with multimeter.. was thinking of supplying power directly to see if it primes.. otherwise issue maybe the power feed from battery??
Other thing to check, silly as it is, is the Cam Angle Sensor... if the plug comes losoe it will crank with no go.
Happened to me once, I felt like a tool.
umm good point.. on the day of power run.. i could see the mech doing things around there and fpr.. perhaps he didnt reconnect it properly..
update - fuel filter is clean, have injector pulse and spark. Can any1 help out with rb20 or 26 CAS near parra today??
call me on 0434284342
If the CAS was stuffed, then it wouldnt have started with the direct power feed would it?
BTW if you want to check to see if you're got the same problem as me, the fuel pump control modulator is behind the trim on the drivers side back seat. You need to take the drivers seat belt top mount off to get at it. I also have the back seat out ATM because i was tracing wires....
issue fixed.. fuel pump and relay earth both werent working.. created new earth new the fuel pump control module and one on the relay.. car started fine thereafter..
only issue now is fuel priming now doesnt stop after 5odd secs now.. just keeps going.. im thinking perhaps the pump relay needs replacing.. any thoughts, will it create problems down the line
Looks like the FPCM also switches at least a soft earth, so maybe the extra earthing is stopping for module from working as well as it should;
From this link
"the factory ECU's on R32's trigger a soft earth for the f.pump; lower flow at idle,". Check the rest of the thread for more info. I certainly got mindf**ked trying to understand how it was all working, but i wasnt expecting earth switching.
umm yeah exactly. the + is always full voltage and they regulate the power via the earth. nissan actually do this with a few electrics (no idea why, 2 stage boost on a 33 gtst is the same). Anyway, the standard fuel computer in the drivers rear drops the earth at idle, you can bypass it by just earthing the fuel pump wire to the chasis. And if you still have problems run a + wire direct from the alternator or battery to a relay and then to the pump. There is a detailed thread on here somewhere on how to do it
fuel pump wiring is a common problem in 32s
interesting.. i have already earth'd the earth wire leading to FPCM so now im constantly delivered full voltage to the pump even when idling right?? will the life span of fuel pump decrease dramatically using it this way.. yet to open FPCM to check for broken solder.. can the relay itself be faulty?
Yeah i think so. The FPCM would switch the earth via a resistor at idle, to lower the voltage at the pump. Since you've made a direct earth it will bypass the resistor.
I'm guessing the reduced voltage is to stop too much fuel circulating and therefore heating up - can anyone confirm?
Yeah but the relay is easy to check. Run 12 volts through the solenoid pins (the pinout is usually stamped on the cover, from memory its the pair of contacts that are the furthest apart). You should hear it click. Check that the other two pins go from infinite to 0 ohms resistance when the relay is activated
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
