hey gary
can you get us the serial # from this 400rwkw Q45
and also a photo if the label?
i think there could be two types of Q45's going around, one is poo and maxes around 250rwkw and the other is OK and goes past 400kw
I don't have that particular Q45 AFM any more, but the current one (just about to go on) is supposed to be the same;
The label is yellow
22680 6IU00 A36-000 P60
1903F
JECS Made in Japan
The R33GTST's rebuilt RB25DET is going in tomorrow, then next week we start on the RB31DET into R32GTST, that's where this Q45 AFM is going. So I will have definitive results for this particular AFM in a few weeks.
There is another variable I have found, that maybe has an effect. It would appear that the R33GTST S2 (and onwards) alternator/voltage regulator runs at 14.2 volts, compared to 13.8 volts for the R33GTST S1, R33GTR S1 and all R32's. I need to test the output/input voltage from the ECU to see if that 0.4 volt difference has an effect on the AFM voltage.
Cheers
Gary
  • Replies 44
thanks - let us know
ive had a few guys come to me using the q45 on mid size gt30+ setups and they max around 260kw
it hits the ceiling pretty quickly in the rpm range, like around 4500rpm so its not a std Q45 ceiling that i would expect
Thanks for the confirmation of serial numbers on the Q45 AFM, They've been sitting here for ages, and I have maxed out Z32, so these will go in knowingly they will produce the goods.
I'm abit happier today than yesterday now.
im going through the Q45 AFM debarcle as well at the moment. Mine goes down to line 16 on 9psi!!! on 24psi its well and truley on the last load point :P
Is there anything i can do to help sort this crap out ?
I got 363rwkw but it was well and truley maxed out, does the Q45 go to 5.2 volts or 5 volt?
Cheers
Ive been threw this, Z32 maxed at 330wkw, Q45 maxed at 350wkw odd (used every Q45 part number as i had access to, use a lot of them), went round and round on what to do, including taking a Z32 or Q45 and cutting the sensor out of it and mounting it into my 100mm intake with a 45mm lexan tube around the bar to stop turbulance and cross flow, a few people are in the proccess of doing this.,
Eventualy I sold my used RB25 PFC on ebay and got a new R33 GTR D-jetro with sensors and everything and it cost me all of $60us difference (got to love how discontinued items rocket in value),
I had to upgrade my fuel system for the new motor so I just got low imp 1000cc top feed injectors with a greddy rail while I was at it.
MAF problems sorted/aborted and no more idle stall with the dual atmospheric bov's YAY
Edited by Rezlo
is that possible with the R34 GTT? i alwyas wanted to get rid of the stupid afms but was under the impression i coudlnt unless i got a haltec or some other ecu.....can i use a R34 GTR D Jetro?!??!?!?
im going through the Q45 AFM debarcle as well at the moment. Mine goes down to line 16 on 9psi!!! on 24psi its well and truley on the last load point :teehee:
At what RPM?
What AFM ramp table are you using?
I can get to 20 on zero boost by changing the ramp table
5.2 volts
Cheers
Gary
I dont know about yours, but Rb25 swap to GTR is fairly simple, injectors, a few wires to add on and obviously the apexi map/temp harness bits and your in business,
The reason I didnt go haltec or autronic was the shear simplicity to do small corrections on the fly with the pfc as well as being able to monitor knock, voltages ectr, here in South Africa our fuel is unpredictable, one can see imidiatly if the knock increases and i can just temp remove a deg or 2 of timing out if need be,
yeah you can use BNR34 djetro PFC if you like
but youll have to adapt it to the 25t NEO - it will need a few changes and some custom mods to make it work
ask a workshop how much to make it suit 25t NEO
Think about it..........set your boost at say 1.5 bar and the MAP sensor is useless, it ALWAYS reads 1.5 bar. So you are tuning off RPM and throttle position. But what if you are at 100% throttle and 1.5 bar? Quite a common occurance wouldn't you say? Then you are tuning against RPM only, that's one dimensional tuning. Compare that to AFM tuning, you have 2 dimensions (AFM voltage and RPM) to tune against. When the AFM voltage maxes out, then you still have RPM to tune against. Which is exactly the same as MAP sensor driven ECU. So tell me where the advantage in going MAP sensor ECU is?
Cheers
Gary
Wouldnt it be fair to say though, that when your doing 5650rpm at WOT, 1.5bar boost, that the engine is using the same amount of air, as all the other times, that those attributes were present? ... ish :teehee:
Edited by GeeTR
answer to this is you want bigger get a 90mm ford lightning maf from the states, there is a guy doing 490hp at the treads at only 4.7v, even if it is american hp (not sure on what dyno was used) its still larger and has more resolution then its nissan counterparts.
if Map was so bad aftermarket and oem would not use them.Yes maf is marginally more accurate, but a correctly tunned map setup will work just as well, usually never even noticible.How many manufactures are moving away from maf and going to map due to reliabitly, packaging ectr, working for an oem and I can't see us moving to map especially with euro 4 emissions if there were not clear advantages that outweigh the tiny bit of accuracy seen on a perfectly clean maf.My biggest love of map vs maf is IAT temps, a most maf cars can not compensate for intercooler efficiency due to most not using iat sensors due to the nature of the maf, map systems have to use iat sensors so it can.
Edited by Rezlo
airflow always increase - look at someone's ljetro AFM logs and check the AFM value - it always increses to redline - map will run to the ceiling value of "boost" and stay there
just found this from the apexi documentation;
Source: Apexi Documentation
80m RB25 airflow meter can measure up to approx. 300ps (221kW)
80mm VG30 airflow meter can measure up to approx. 500ps (368kW)
90mm VH41 airflow meter can measure up to approx. 400ps (294kW)
*Output is calculated off of measurable air volume
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
