Was planning to tow just 1 horse, you need a 4WD to tow any more than 1.
Thanks Dan, looks better now minus roof racks. Also have 18s but they need tyres so its getting there. Got a price on a towbar for that, $850 ex Sydney, OUCH!
Would custom for the Skyline cost more than $850 do you think? Haven't really got the time to sit back and wait, the show season is in full swing now!
Edited by R31 Chick
Not at all. Skyline should be able to tow 1200kgs (I think at least thats what Aus 31's are rated too, couldn't find much on the 33 tho) so will tow my light float and 1 horse, nothing more. The Audi is rated to 1800kgs so would pull that on its ear. Falcodores do it every day too.
I have seen an Accent pull a float (not that I think that is wise to pull over a load rating) so a Skyline won't struggle. My old R31 did it up Greenmount Hill, again it was fine so why shouldn't an R33?
Edited by R31 Chick
hiya bailey
now word ive heard is that with some minor mods a s15 (local) towbar will fit a r33
mind you this was for a jetski not a horsefloat (weight difference? )
i dont think its the pulling power of the line you should be worrying about its the structure in the rear end is it really strong enuf to support a 1200kg load
mabe try asking at the major towbar/ bullbar places
Horse plus float weight would be about 1200kgs. My old Aussie 31 was rated to safely pull that. I was guessing the R33 would be about the same? The Audi is rated to 1800kgs although I wouldn't put that on the back of it.
Would only be using it in emergencies or the odd horse show as my Dad is gonna buy a new 4x4 eventually which I will use but the ML gearbox is flaring after towing a couple of horses around for a short time so bit disappointed with it.
Not sure you could get a 4x4 for under $2000 even that I would feel had enough frame that hadn't rusted left to put a float on?
I don't want to put my horse at risk so it isn't damaging the car that worries me but rather something going bad and my horse being hurt. I tried to find out the R33 safe ratings but can't find anything. Does anyone know where I can find it, nothing came up on google.
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
