Originally posted by riggaP
I just put in a new head unit and I aint got no radio coz the jap adaptor dont fit.:)
Anyone know where to get one that'll fit???
Its a Pioneer DEHP6350 if that helps...:)
My Kenwood came with the adaptor,,but it took me a while to work out how to do it or even what it was for,,,in the end it was so simple,,,,All it was,,was an adaptor that pluged into the Head unit(just like an Aussie aerial plug lead) and the Nissan aerial plug end fitted into it....with the 2 pin Nissan one,,,one pin went in the middle(the Hole) and the other pin rubbed up against the outer case of the adaptor,,,,,Simple. I bought my head unit from SCR,,,maybe they can help you....
Neil
https://www.sau.com.au/forums/topic/2062-jap-aerial-adaptor/#findComment-39558
Originally posted by nissanpower
does anybody know how to tune the radio frequency thing. cos i can only get fm range from around 70 to 89.9
its a japanese pioneer headunit .. carrorezia or something
Easy buddy,,,Jaycar and the N.Z. boys sell whats called a Band Expander,,,,It's a adaptor that double adapts between your stereo and your aerial lead,,,,you do need to find power though,,,,use the cig lighter....Just make sure you get one for the 2 pin Nissan system.
Neil.
https://www.sau.com.au/forums/topic/2062-jap-aerial-adaptor/#findComment-39559
    • I had issues with my car today after removing the rear bumper. The headlights aren't working when turning the stalk but high beams are working and the rear tail light where the reverse camera is wired up won't turn on when the stalk is activated, but the reverse camera, tail light indicator and brake light all seem to work. I checked the fuses they aren't blown. I think the reverse camera could have possibly gotten pinched but shouldn't be as there is a decent amount of room. I did use the lights and loom for the license plate from the new bumper but also tested the old one in case but made no difference. This isn't for a skyline also. Any ideas what it could be? It was working when I drove I'm pretty sure, then on my return home I noticed my headlights weren't working.
    • IMG_6023.mov   In motion 🤙
    • If we're going after market gauges, I'm a big fan of Australian made... Get some RedArc!
    • Unless you're fortunate enough to buy a newer car, getting an older style plate to match your name/car is difficult because they've already been purchased.  Unlike other countries, personalised plates are locked to the country and not region, so there can't be multiple versions of the same plate but with a different area code.  Hope that helps
    • People use the numbers to make it look like letters to spell words/names, which is where the illegal spacing comes in. For example this GR Yaris
