they are H1, u will need 1 for each light .. just open the bonnect look behind the light .. its very easy once u see it... twist the cover open.. play around with the clip that holds it there ... you'll know when u see it .. and those blue xenons i don't think are blue at all .. just white .. they turn less white after a while of use ..
hope that helps
Get Philips or Osram. Both brands sell very good quality blue and white bulbs. Most of the other "blue" brands produce the wrong kind of blue (there are exceptions but I don't know of them). I am going to get some Philips white bulbs myself. They're only $80 for 4, but I am holding off until I get my tax refund. My insurance came in and it hurts :P
Narva bulbs are over-powered to get their brightness and as such tend to fail early.
well from what i know pretty much everything out there is pretty shit .. there is one brand called ... damn i can't remember ...oh yeah its PIAZZ ... its what u find in BMW and all them $$$ cars stock ... they are the whitest and brightest u will ever see ... but i think it costs like 150 a pair ... my cousin had them on his R33 and they looked the goods ... but if u can't afford them ... well just do what i do and get whatever cause you're goign to be replacing them heaps heheehe ... just don't get any grease on the bulb or u will be replacing them even more ... :mad:
The only place that used to sell them was a place in melb that closed down.... they were like $150 a pair but were marked up heaps. I got mine for like 70 bucks a pair from Hong Kong. There must be someone around in Aust (even a mail order place) that can get them for under a hundred bucks
The Philips Vision Plus I want to get are $40 a pair from Autobarn. I think Covingtons might be a bit cheaper, I will check there before I buy. I think the blue ones are in the same price range.
Hippy, I don't think they're illegal, but ask the shop guys. If you don't want to take their word then maybe ask the RTA, or just ask the cop when he pulls you over :D
Kdawgboostin33, I wouldn't bother changing the parkers. Why would you want to?
Hi Guys, though i'd post up some pics, theres hardly any difference looking at my crudy photos, but I have to say it really makes a difference when driving, i'd estimate about 30% better.
These are Philips Vison Plus ($39 from Autobarn) they were actually the cheapest ones they had. They have blue tips, but there is no blue element visible both when driving and looking at them from different angles with the naked eye.
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
