tru tru but with a lil bit of work and less than $50 u can make ur can extremly hard/impossible to drive off in. Sure if some1 does break into your car they will probly leave with stereo and you have to deal with broken windows etc, but you can still drive home
flame thrower alarm ftw
Nice, can't say they don't deserve it.
Also, where can I find these kill switches? Been googling them and can't even find info on how they work let alone someone who sells them.
Thanks.
Edited by KezR33
$500 shit box, great for driving on curbs, hitting speed bumps at 120km/h, and playing bumper cars on the freeway (Mate actually did this!!). Also good for parking in dodgy areas, and petrol is cheaper as well.
you would have to either work at the place for a very long time, or live very far away, before you started to save money on fuel considering the $500 initial investment, not to mention insurance, rego, and repairs on a second car
this is a kill switch. basically u connect the battery...THRU this switch. when u turn the switch off. u kill the circuit.
but hide it better than ^^^^this eh.
its basically a "master switch". all the power runs THRU it. and when u turn it off it breaks the circuit. hence no power
Edited by r33cruiser
yea some are like that, most i have seen they just pull out, like a key, mount one in your fuse box under bonnet and when you park somewhere dodgy jus pop the hood pull the pin/key and walk away.
ps. That flamethrower alarm.... haha that would be awesome haha
autobarn,
switch,relay and terminals.
i actually got the swtches and relays form jaycar on logan road at underwood...
im actually half way thru doing this now... i started it yesterday but i forgot to bring my crimpers home from work so i can finish it... DAMMIT!!!
all ive used is
2 x 4-Pole relays (with bases and relay clips)
2 x small red switches
1 x small black push button
small strip of din rail
and some multi-core cable from work
ive wired it up as such so that to start the car... there is a main switch (1) that must always remain on (unless u never wanna start the car) :D another switch (2) that must remain on... and a push button (3) that is used to allow the car to start... if (2) is not switched in the on position then pressing (3) wont allow the realys to hold in and the car cannot be started... but if (2) is in the on position, then by pressing (3) the relays will latch closed, allowing the car to be started...
im using the relays to cut some of the wires to the ecu...
also, being an electrician has helped me... lol
ill post some of the photos ive taken so far later on today... im on my laptop atm and they're on me other computer...
some photots so far as promised...
Button and Switches
Completed Wiring of 4-Pole Relays
ill keep taking photos of this installation and ill post them all up on here with a description on parts and how to install once completed...
Edited by gumflapper
all ive used is
ive wired it up as such so that to start the car... there is a main switch (1) that must always remain on (unless u never wanna start the car) :) another switch (2) that must remain on... and a push button (3) that is used to allow the car to start... if (2) is not switched in the on position then pressing (3) wont allow the realys to hold in and the car cannot be started... but if (2) is in the on position, then by pressing (3) the relays will latch closed, allowing the car to be started...
nice work, I did something similar minus the extra switches, out of curiosity which wires did you break from the ecu? I ended up doing the fuel pump relay but wanted to kill the ignition or afm but couldnt find the right wires I tried a couple (using ecu pinout diagram) but got annoyed at cutting wires and the engine still able to run. I also wired mine so that the relays can only be energised once the alarm is turned off and the ignition turned on and when the car is turned off the relays unlatch
Edited by SevenAngryPenguins
  • 3 weeks later...
hey does anyone use wheel clamps here? are they any good? I'll do anything to prevent my car getting stolen... I wake up in the middle of the night everytime I hear something that sounds like my car!
do you know where I can get one for a good price???
    • This is the territory of the "Stage 1/2/3 Golf GTI/R" or otherwise off the shelf tune with (relative to before) minor mods. It's easier now. Downpipe and Tune and boom, big increases. Stage 1 OEM+ is where it's at. This is where the niche evolved into and it's really easy to see why. It's rare to even NEED to consider changing turbos or going to aftermarket ECU's or building bottom ends for more power. Stage 1-2-3 will get you a LONG WAY. Civic Type R turbo GR Yaris/Corolla Anything with B58 (MKV Supra/x40i) Anything BMW in General Anything Audi in General Any turbo AMG RenaultSport Turbo offerings Korean Elantra N/I30N Ecoboost Mustangs Focus RS? List goes on. I would argue in the future it won't even need to go on... M3P is pretty rapid out of the box...
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
