Hey I've done a little searching on the matter but haven't been able to find what I'm looking for. Anyway, my GTR is slow off the line, what sort of things do I need to add/change to give it a little more take off without having to dial up a heap of revs.
https://www.sau.com.au/forums/topic/206463-gtr-off-the-line/
Although that is fun, its not so good on the street. The car just feels heavy off the line, should I just assume that because of the gtr's weight and the 4wd that it will always be heavy, or can this be helped in some way, like with a better flowing exhaust or something like that.
i got a lightened flywheel when i did my clutch and the ease in takeup at low revs was very noticable especially for normal day driving. it was a completely different car to drive. not sure if this what your after or if it is suited to you
wow thats interesting...I was always under the impression that lightened flywheels only helped in the higher revs..Thats the second person who reported better low end torque from the lightened flyweel mod
lighten flywheels help alot in engine response.
I know TODA do a really good flywheel...they come in many specs from mild street to outright race...So response has improved ...howabout low end pull...like take off without the big revs...better by a noticable amount right ?
GTR's will get that. The car is alittle heavy for what it is OR can be a bit lighter. Basicaly you feel the car getting "bogged".
Getting a good launch = rev the car to about 4000rpm + to get the turbos spolling and engage the clutch.
Lightweighted flywheel will help alot and twin clutch plate but I will go single Extra heavy duty.
you dont have to launch them hard to get off the line quicker, with a heavy duty single u should be able to bring it up to like 3k and then just ride it a bit off the line. Not as harsh on the various components that way compared with like an 8k dump and still reasonably swift... any1 else agree?
its kinda feeling where with the old flywheel when you just engage it bogs and doesnt want to go but with the lightened flywheel it wants to go....your expecting some lag but its just not there anymore. all normal street, carpark driving. maybe its the combination of the cushion button engaging better? mind you i did get adjustable exhaust cam and a light tune but the car is rediculously more responsive than before.
My experience with a lightened flywheel suggests it will rev faster but bog down more. I had a 240Z with a 8lb flywheel and it would rev so fast but you had to really slip the clutch to get moving. And a 240Z only weighs about 2/3 what the skyline does, of course without as much power. A lightened flywheel doesn't have as much momentum built up on the revs so there is less to transfer to the drivetrain when you want to get moving. Once moving you will feel the difference in acceleration.
I'm really curious on this too. The latest HPI Skyline special has an article on going 11 sec 1/4. It says to take your GTR to the rev limiter and hold it there, count to five and dump the clutch. Sounds like a drivetrain failure wanting to happen to me.
So do most folks here launch between 4-6 k revs? How much difference does it make on your 60 foot times if you really launch hard?
Keenly interested too. thx.
Edited by Pezhead
^^4000RPM is quite a bit.
1st time I was gettting use to my HKS twin plate, I accidentaly revved it and launched at 4000RPM and I was pushed back in my seat and cought up to the car which was about a car length ahead of me.
I was like "WTF! Geez! What the Hell! Then got use to it. LOL!
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
