so I put in the motor today realized all the piping from the rb26 is too short due to the height of the block is different
since I have to remake all the pipes already I think thinking of either v-mounting the intercooler or mid mount it up against the rad.
this car will be driven on the track most of the time and sometimes dragging
I will also make all the proper ducting for both the rad and intercooler and also a big hole on the hood for venting of the IC
any suggest for this set up on A track car
Btw I saw tuff tunes r324 with the v mount set up !! It looks amazing !!!
Edited by felixy69
I think with a gtr your really going to be pushing for space with a V mount. or be using a very small core. or perhaps a long and thin core could work.
if your a member on nissan silvia..
ase have a v mount kit for 180sx(s13)
to give you some idea about room i can stand inside my mates 180sx engine bay as there is alot of room infront of the motor for a v mount setup
Edited by Angus Smart
i think that the gt cars thats actually the radiator mounted that way. with quiet possibly the intercooler below..
also you notice that the engines are not in a normal location they would be atleast 1/2ft back
Beh, you can engineer it for sure. Ppl do whole tube frame front, tilting f/glass front sections..
Unless something has changed lately then...
Check with a structural engineer, to see how much of the front radiator support you can cut out; would allow you much more flexibility.
:thumbsup:
you will not get the air you need to cool it in a v-mount setup, think like an air molicule it wants the path of least resistance if you go changing the angle of the cooler the fins will be facing downward and the air will only pass through a small part of the fins..this is only my opinion and I strongly detest vmount or angle coolers/radiators..
I guess the concept is that a lot of air doesn't go through the cooler at all; it buffets over the bonnet, under the car, around the sides.
With the small eddy's in front of the cooler, i guess another direction change (through the now angled fins) doesn't impact it do much.
Rem too, instead of air going through the IC -> Rad, then into a already hot pressurized engine bay, -> off the firewall and down under the car... half the air (assuming IC is on top) is going out the bonnet. Its getting sucked out the bonnet actually.
in the case of denzo the greats car I just cant quite understand how he is getting the air threw that cooler, must have some serious ducting, I know gt cars use it and it must work to an extent but they must have used thousands of $$$ in R & D doing it.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
