I just visited the RTA and was absolutely ass pumped at the end of this lenghty process. I was slugged with an additional $660 charge. Total rego only cost was $1070. This was in sydney. Dose this sound right ? How much is everyone else paying ??
Really? Is this for a newly-rego'd car? If it is, I can't help you, sorry - I bought my car from an owner who lives in NSW already too.
Ouch :cheers:
https://www.sau.com.au/forums/topic/206587-stagea-rego/#findComment-3654485
Yep, NSW rules are very different.
Just one of the differences: we need to do roadworthy tests every year unless you buy a brand new car, in which case you're exempt for the first 3 years.
https://www.sau.com.au/forums/topic/206587-stagea-rego/#findComment-3655594
Rego? Or stamp duty? Inspection fees? Number plate cost?
https://www.sau.com.au/forums/topic/206587-stagea-rego/#findComment-3656016
Hello,
It appears that someone has either calculated it wrong or has entered the wrong details.
I just did this on the RTA site for a new vehicle....which is exclusive of the green slip $350-$450....
Body type: Car, station wagon or small bus Registration usage: Private Tare weight/Capacity: Extra Large (1505 to 2504 kg) Market value/Purchase price: $25000 Charges($)Registration fee 51.00 Motor vehicle tax 331.00 S yello-issue fee 35.00 Stamp duty 750.00 Total 1167.00
Edited by Paramour
https://www.sau.com.au/forums/topic/206587-stagea-rego/#findComment-3656264
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
