Motorplex meet.
  • Replies 233
Originally posted by MrSnrub
Hey Radium....was yours the 32 with the roll cage inside?
If so i ran against you a couple of times...didnt realise it was you.
yep, once she's licenced you'll recognise her and me alot better as i have my [RADIUM] plates in storage awaiting to be placed on her :P
were you the two toner?
I was gunna come over for a quick chat over in the parking bays with you guys but I just wanted run after run. :) i managed 14 in total.
strich: my brother in law owns Speedfreaks and he just sent in a letter to apply for them and received a call as soon as the letter came in for him to come and pick them up, theyre cheaper than a years worth of rego theyre coming in pretty handy.. not a single hassle from the cops whatsoever, be it during the day or 3am driving through northbridge. *TOUCH WOOD*
Shaun
Well on my way home from indoor cricket I got onto reid hwy coming home and sure enough the car pulled hard to 6500rpm through 1st/2nd and 3rd, with the boost set to 0.8bar. The only difference from tonight and sunday was the ambient temperature, maybe my stock intercooler is full of crap and needs flushing or cleaning, should try and have a look.
Rob
Originally posted by Gradenko
Yeah, anyone know where we can get a hold of 2nd hand drag slicks? Not circuit racing slicks, their stiff side walls would be useless for drag racing.
Circuit racers will be alot better than your low profile street tyres let me tell you!
2nd hand Drag slicks are usually 14 or 15 inch jobs so finding a suitable rim will be a hassle.
Why not save up for some BFG Drag radial TA's they are low profile and are real 'sticky' street tyres. About $300 or less a pop.
Yeah thats Michael my mate from work.
Thats fast that little thing......S13s are a wicked "Bang for your Buck" car. He ran 13.66 on street tyres. Another S13 ran 13.5 but he was using slicks.
Michael has only got pod, exhaust, intercooler and 15psi..... not bad. We are just about to ordered a SAFC ($472) each...
Adam - his car didn't blow up it was just a part of the intercooler piping came off but it was easily fixed on the spot. You can't laugh anyways.......... :D
Ben
Adam 32..
your mate with the 180sx running 13.4 ?
what sort of mods does he have.?
I've got the fmic, t28, zaust and pod and running 1 bar for now, apart from the couple of extra pounds, does he have anything i don't..?
I'd be stoked to think I could get close to that sort of time..
cheers
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
