  • Replies 166
Originally posted by -Joel-
Now.. Wouldn't that be fun.. I wonder if private track hirings could be arranged. :P
i have been talking to the owner last time i went to the drift day about hiring the whole track myself:D , quite cheap actually. We can arrange a small group of people to hire it for pratice, and attend the next drift day;)
i keep asking for the price for the whole track, but maybe i am a kid, he don't think i can afford it.
what he told me was forget about weekend, go at weekday, which will be $20 a day!!! from morning to late, he will kick u out if he has go-kart race at the afternoon, but u still got the whole morning, which is more than enough.
steve, i have PM u his contact no. , give him a call about the information for hiring the whold track, hope we can have a SAU drift meeting soon :(
its amzing how much you guys all care bout your cars but you would be willing to put your car through such punishment
going for a drive through the hills is totally different to drifting on the track!!!
i get worried im gunna break something when i drop the clutch sometimes
anyone else have same opinion
or do i just sound like someones mum
erin
Erin, my mum is a rev head, but my old man....
I wouldnt push my car past its limits, and as long as you dont then you shouldnt have any problems.
Skylines are designed to be driven hard, not as a shopping trolley/commuter - have a bit of faith in the nissan engineers and watch the grin factor grow:D
I used to also be worried that I would break something when I drop the clutch etc... This was after owning a series of cars that would break when dropping the clutch.
I.e My old 250 Cortina that I done 6 manual gearbox's & engine mounts, I worked on roughly the second clutch pressure plate that I would blow so would the gearbox, then my VS Commodore where I done a diff, gearbox, engine mount and the rear irs chassic where the diff bolts on cracked and the arse end dropped on the ground. I owned the Cortina for close to 2 years and the Commodore for 9 months.
I've now owned the Skyline for around 2 years and nothing has broke. After many many flat changes a couple of burnouts and well a lot of hammering.. Nothing seems to break.
I am honestly more worried about hitting some thing in the hills than breaking something as I guess my confidence has grown in the car that it is tough. Something is bound to break but not any time soon, Unless I upgrade the clutch to a twin plate or the likes that will enable a 4th gear chirp.. ;) The current clutch has a bit of give so i guess that is why the drive line has stayed intact.
Mind you the car is starting to body roll a little on its stock suspension so shockers are in order.
yep the good ol' Single Rail..
I learnt how to rebuild it after the 2nd.. Sat there with a tub of grease sticking on the lay shafts needle roller bearings.
For a full rebuild it would cost $80 in parts.
To get some one to do it they wanted close to $500, and even then they probably wouldn't have done the layshaft bearings.
The layshaft bearings can be heard from the rattle of the gearbox when you are say in McDonalds riding the clutch a little and creeping forward. The Nissan box doesn't appear to have it however my Old VS Commodore box did before and after the rebuild. This is how I know he didn't rebuild it totally. For just over $1000 I wanted the layshaft bearings replaced.
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
