Hey guyz anyone got pics of R33's with LED tail lights and where could i find them, i aint looking for the dicky chrome ones..
Thanks
Chris
eBay perhaps?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=200200461403?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=110225877433?
I saw something like that but instead of the chrome it was the same color as the car?
Look closer @ it, im pretty sure this is how u buy all of them for Skylines. Look at how the chrome aint flush with the light.
After u buy them, u take the shell/surround of the stock lights and put it onto your new LED ones.
You're right about the surround... ...these are the same as the ones AutoBarn stock... ...I've been looking for something like this too... ...but I want them to be totally clear... ...No red... ...until the breaks or drivers come on... ...I just don't like the look of the small red dot in the middle...
I've seen some frosted white ones at Autosalon... ...But they didn't look like they had LEDs in them... ...Just couldn't find the owner of the car to ask him where he got them...
Anyone know where I can get these???...
No Red = Yellow Sticker - ADR's require rear lights to have red reflector that is highly visible when struck by a beam.
Why go clear? the stovetops are part of what makes a 'line a 'line IMO, semi unique to the lineage (i realise that there are others similar, but it's the only one i can think with four distinctly separate lamps)
Yay i've finally been spotted!
Hey guys, this'll be my first post, been browsing for a few weeks and going to sign up march 1 at RE Customs day. I'm the owner of the frozen r33 with a jurassic theme going on - not many people got that at autosalon, they thought it had water and clouds and shit going on but the car itself is frozen! U see me around i'll stop to say hi.
Anyways, as for my tail lights they are LED's when the lights come on. I made them myself. what i did was:
Brought some old ones from the wreckers to do a test first in case i stuffed them up
put a drill hole in the middle of the red lenses
got a heat gun and used the holes as leverages to hold onto while i pulled them off (its actually 1 piece joined in the middle but the glue just goes all around)
had my mate at a plastics place make me up some inserts which the LED's were drilled into and put together
then i got him to make me up some surrounds which i used his plastic glue to put back together!
it's that easy - the insert piece which holds the LED's goes behind the circular rough edges insert just behind the lenses, so it looks sweet and uses all the original parts
if you got any questions, or want some more pics, gimme a buzz
otherwise hope to put some faces to the usernames when im there next weekend
shanus
shanus
Ahh... ...I hung around your car for quite a while that weekend to ask you about them... ...But had to stick around our own display...
I'm guessing from the photos you put up that the reflector inside is white/clear and the whole outer cover is the red part...
yeah that's right. once you open up the 33 tail lights you'll see that the way they shine red is only by the red lenses covers. The inside reflector part is plain and has nothing to do with its color, and chucking in a red globe or red LED globe on it's own is not enough! But the bonus is the circular rough edges outer part just under the lenses is already clear, and reusable! it would look crappy if this part wasn't re-used. i'm pretty happy with the way they've turned out, and surprisingly it was the most frequently asked question everywhere i go. cheers
  • 6 months later...
correction... require reflector. doesnt have to be red.
clear reflectors will do just fine
pushbike clear reflectors are cheap and can be fabricated to replace red ones in tail lights
Woah... ...Digging up old threads... :P
  • 4 weeks later...
mine are now for sale - i got sick of the clear look and i wanted to take most my car back to standard for less reasons for cops to annoy me. if anybody is interested pm me. looking around the 250 range, the leds alone cost over 100 and i had to buy some spare sets for another 100 then all the plastic parts custom made so i'm out of pocket but will negotiate.
cheers, shane
and you dont need to tell me if you think they are awesome or ugly, i dont care for opinions, just want to move them on thanks.
