Alright got the day off and decided to do some work on my skyline...heres what i did:
Put a vent in the bonnet (mainly for looks but hey might help keep things cool)
re-sprayed the front grill.
re-sprayed alot of the interior.
I think it came up alright, let me know ur thoughts : )
Oh and with the vent yeah i know its frowned upon but i havnt touched any support bars just the top sheet.
Edited by nikr33turb
https://www.sau.com.au/forums/topic/207251-got-bored-then-productive/
with your bonnet vent won't the edges of the sheet metal just rust now or did you seal it as well...?
Your pretty game cutting into your bonnet like that I wouldn't have the guts knowing what it would cost to replace.
Its right above your air intake and I'm guessing your have a pod filter, yes, what happens when it rains? unless of course you have your pod enclosed but then why would you need an intake there....
I have a vented fibreglass bonnet with a vent near the airintake like that but its not flat, it would only get water in when moving and then it has a bit of a draining area.... I can't imagine how much water would get in if left out in the rain like that....then you have a wet pod...
interior looks ok... but woah that grill.... I dunno
^ agree with above
Yeh i hoped you sealed the edges cos its gonna rust. And its going to get water into your pod if you have one. Dont see that it would keep under bonnet temps down at all in that position. Perhaps if you just want the look you could seal up underneath somehow. i dunno. I give you credit for having the balls to cut your bonnet but its not something i would do.
Interior plastics look cheap
Grill looks good to me.
+1 for having the balls to chop up a perfectly good bonnet :D
you realise that vent isnt drawing any air in, right? its just flat, and all the air will flow right over it. so the only real benefit is that some hot air might escape through it. but then being where it is, and such a small area, i doubt it.
Yeah ive sealed all the edges and have a cover that just goes over the top of the pod so rain shouldnt be a prob..and i want a carbon fibre bonnet so i figure if something does go wrong then i have a good excuse lol
It looks cool. Altho it looks weird with just a random vent, you should cut some more, or at least one on the other side, altho ur fuse box is there, so not a good thing. But it looks good, and that grill is so cool. Nice interior, I'm looking at doing something like that on the long weekend! Good work, I wouldnt have the balls to cut a perfectly good bonnet either!! Even if I was going to change it later on
Sorry to say, but that bonnet vent looks tacky. Obvious "backyard job".
If you wanted an excuse to splurge on the CF item,... you should of just invented one rather than hack into a perfectly good bonnet,.. but each to his own.
The front grill looks ok, you should get CF dash surrounds instead to match your future CF bonnet. Would look much better.
I don't agree. The interior matches the exterior, and draws it all together. But as you said, eash to their own.
Nick, do you have any close up photos of the interior painting? I'm interested to see how well it is, because everytime a car comes into work with painted highlights, it looks like shit! I want to do it myself, but being a perfectionist, it must be perfect!
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
