  • Replies 51
see what i was talking about??? having the ugly guy (no pun intended) in the middle ruins the picture :banana:
the clipsal girls seem to be hiding at the moment, hopefully some nicer weather can entice them out tomorrow
https://www.sau.com.au/forums/topic/207290-clipsal-pics/#findComment-3667681
^I just have a dislike for fishnets... sure, the girls are there to be a bit of eye-candy, but I think the stockings ruin it making them look more like whores than good ol' eye candy.
yeah gotta agree with that Eye-candy FTW
so Guy you haven't gone looking for Mrs Jennifer Hawkins for a photo? If you lucky you'll come across her :banana::P
Edited by Whiplash
https://www.sau.com.au/forums/topic/207290-clipsal-pics/#findComment-3667873
Jennifer is old news, she was replaced by the new Miss Universe Australia - Kimberley Smith
Who I just happen to have a picture of
Perhaps its my photos, but some of those girls would put a horn on a jellyfish ;)
Edited by 4door_Sleeper
https://www.sau.com.au/forums/topic/207290-clipsal-pics/#findComment-3667955
i know one of the grid girls, havent seen her in a long time.
maybe i should make an attempt to see her. yknow, "see" her..
btw, those 4 chicks in white are, um, not really there for their looks are they?
Edited by ted180
https://www.sau.com.au/forums/topic/207290-clipsal-pics/#findComment-3668091
that is blasphemy Guy - and I will slap you in the mouth for it tomorrow. And fyi Kimberley is PLAIN JANE - she is not even in the same ballpark as Jen
If I met Jen at the track, needless to say I would be in need of some handy wipes .... speaking of which enjoy a few of my pics below :( (just for you Nick lots of them are GIRLS only - without my ugly head in them :) )
https://www.sau.com.au/forums/topic/207290-clipsal-pics/#findComment-3668101
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
