Just a few things i was hoping some of you might be able to help me on. My rb20 in my silvia is only getting roughly 330klms out of a tank. The tank size is 55L. This was with relatively easy driving etc. Also, the cars idle rises and falls dramatically sometimes at idle. Does anybody have any ideas what i should be looking for as to fixing this problem? All the rb has done to it is a k & n air filter which came off the old engine that was in it. Thanks for your help.
Jase
https://www.sau.com.au/forums/topic/20762-rb20-probs/
Check the idle control valve, or whatever its called, on the back of the plenum. Pull it off and hit it with carby cleaner. They tend to clog up a bit and cause a fluctuating idle.
That economy is pretty bad, I get min 400kms per tank local driving with filter, exhaust, intercooler, boost controller and i don't really drive slow. Up to 530km on longer distance driving.
This is generally taking 53-55L when i fill it up. RB20T aswell.
https://www.sau.com.au/forums/topic/20762-rb20-probs/#findComment-437744
I would almost bet my left whatever that its your oxygen sensor. I had the same problem with my car, disconnect it and see if it idles better. When i got a new one, the idle was perfect and a big difference in fuel economy (I had to disconnect the faulty one till i found the new one)
https://www.sau.com.au/forums/topic/20762-rb20-probs/#findComment-438853
I think the problem has been solved. My ignition timing so was retarded it wasn't funny. Now it seems to be very conservative on the petrol and is going heaps harder!! Still have the occasional up and down idle tho so i will take that valve off and give it a clean. For all your rb20det people, i peaked power at 7200rpm, does this sound normal??? The dyno i was on was a bit out of whack too cuz i only got 73kw's at the wheels!!! hehe.
https://www.sau.com.au/forums/topic/20762-rb20-probs/#findComment-439254
Yeah, I had the same problem after my conversion. While doing the conversion, in an effort to work out why I wasn't getting ignition, I mucked around with the crank angle sensor and when I finally got it going, it was retarded so on idle, it would nearly cut out then rise then nearly cut out again, one of the first things I checked was the CAS and this solved the problem.
https://www.sau.com.au/forums/topic/20762-rb20-probs/#findComment-447281
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
    • Continental have consistently beaten the absolute shit out of every other performance tyre in Wet/Damp/Cold conditions and give up a little bit of time (half a second at most) in the dry. Almost like it's engineered for German conditions or something. I'd def give those a try.
