If you want to do any street driving I would recommend going for a built jatco re4r03a as you still retain the overdrive but they are expensive compared to something like a C4.
The overdrive would be nice for street driving, granted, as would the bigger and stronger components of the RE403 over the Skyline 401 but like you said, they're much more expensive to build to take the power being suggested than an equivalent C4 or TH400 which are known quantities where spares are very readily available.
If it came to it you could get Mike from MV to put a JATCO together as he does some good work at reasonable prices but the standard Jap boxes are too hit and miss when you start leaning on them hard. I'd stick with something that you absolutely KNOW will do the job time after time.
https://www.sau.com.au/forums/topic/207633-drag-driveline/#findComment-3677753
cool thanks heaps...
ive heard the jatco's arent as strong???im not going anything nissan i have big plans for future and dont want to change but i still know next to nothing about auto's...
What about powerglide???
Any other choices or c4 is def the pic???
You could quite easily adapt a Turbo 400 or Powerglide to your engine but it's all about what you want to do with it. Having a third ratio is good for cars with narrow power bands. What does your car weight and how does it make its power?
The C4 is a relatively light and small (narrow) box as well so it's a good option in a drag car where every pound counts.
https://www.sau.com.au/forums/topic/207633-drag-driveline/#findComment-3683003
A built C4 is a strong box but dont under estimate the re4r03a as testing in the states indicates that these boxes will survive 1000hp and beyond.
The question is for how long, mate. Dom Rigoli had an RE401A in his 1000hp WRX for ages but how often was it pulled out and at least checked each meeting? It's a lighter car than ours too so who knows. 1000hp is one thing but in a 3300lb car it's a whole other story. C4's and Glides can hold that power in a 3500lb car all day so I know what I'd prefer.
https://www.sau.com.au/forums/topic/207633-drag-driveline/#findComment-3686510
The problem with the subaru re4r01a is that the output shaft is very small compared to say a skyline re4r01a and half the size of the re4r03a. Once they upgraded the output shaft size to powerglide spline size they had no more issues with breaking output shafts. I will be testing the limits of the re4r03a boxes soon. We have kept the shafts standard (other than heat treating) to see what weak links show up. These are larger than a v8 glide so any problems should be fixable using higher grade steel.
https://www.sau.com.au/forums/topic/207633-drag-driveline/#findComment-3686587
Lost them there Smiley
https://www.sau.com.au/forums/topic/207633-drag-driveline/#findComment-3709416
  • 1 month later...
probably worth a mention that with the rather large turbo you are running and depending on how
tight the converter is you will probably have to give the big girl a sniff to persuade it to come up on the brake. A small dry shot will do it, something like 50hp. Unless you want to be on the start line staaling it up while the other car crosses the finish line like most VLs you see
https://www.sau.com.au/forums/topic/207633-drag-driveline/#findComment-3810001
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
