hi guys
i gave the wrong oil to my mechanic.
The motul website sez motul 300gear oil is for non- LSD diffs and ive got a r32 gts-t
it cost a packet too. those wanks at autobarn, I said to the guy "are you sure?" and he said that "motul Gear Competition is only for the GTR"
im i gunna hafta chage it?????
it should be alright with the Vicious LSD, however if you have a clutch pack type such as a 1.5 or 2 way, you'd need a LSD type oil,
failing that, you can go get an LSD additive to add to your current oil, sould get a small tube of something to squeeze into the diff
To be on the safe side i would change it....
Never take advice from guys from autobahn/repco or any of those kind of shops... If they offer you advice just smile but dont take any of it into consideration. :)
Why didnt you mechanic notice when you gave him the bottle?
You can do ur diff oil your self... isnt too hard. 1 bolt down the bottom of the diff drains your oil, another bolt on the side up the top to fill it up with.
You can pick up a little hand pump to get the oil in there which you can keep for next time you do either gearbox or diff! ... Too easy!
Hope this helps~
THis one seems like a good idea as well...
Edited by br3ndan
hey, god i wish my girl was as fast at replying as you guys hahhaha. thanks for the input.
it MAY be ok, i gave the car to the mechanic tonight and i HOPE he hasent started yet.
ill call first thing in the morning FINGERS CROSSED.
will the LSD additive be ok long term, is this a common thing to do???
its quite common, and its perfectally fine to do so, LSD oil is just normal gear oil with an LSD additive already added.
as i said, if its a vicious diff, it wouldnt matter if u used non lsd oil or not...
its the stock diff so im guessing its a vicious r200 right.
if so its all sweet and the guy at autobarn fluked the right answer (ill never give em credit for anything)
can someone confirm?????
Give the distributer a call, probably the best way of getting the right information. Also autobarn, repco etc. have brochures on the oils, which will give you an accurate listing to what oil you need to use... The guy serving you obviously didn't look it up and that's a big no-no as autobarn is now liable for any damage done to your car if it turned out to be the wrong oil.
  • 4 years later...
I prefer herbal products as they are safer. These Indian ones are great. proventil albuterol My friends were curious what happened that I lost some weight and look joyful. When I revealed my secret they also decided to use Acai berry.
proventil albuterol
proventil|albuterolbuy Proventil Inhaler
proventil inhaler generic
generic albuterol
salbutamol generic
buy lamisil no perscription
differin cream 0.1 45g
acne cream differin
Go spruik your witchcraft, hocus pocus formula some where else you thread grave digger!
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
