Congrats, that's cool.
I saw your car at "super sunday",... had no idea it was set up for drift.
Now you just need a nickname so you can go up against "driftcat".
Female drifters kick a$$!
Look forward to the slippery hpi issue.
https://www.sau.com.au/forums/topic/207763-51pry-is-famous/#findComment-3677177
We all knew it was bound for great things when she painted it yellow :D
Would have been good to get Tiff and Vish's car together with my old car for a few pics...
Oh and that yellow HR31 GTSX that came to SCC07, would have been a nice hand of cards...
https://www.sau.com.au/forums/topic/207763-51pry-is-famous/#findComment-3677883
Thanks for all your feedback!
I think we are about due for a YELLOW only photo shoot... :D:D:)
......and lets not forget 00R34! :blush:
https://www.sau.com.au/forums/topic/207763-51pry-is-famous/#findComment-3678051
The photos look better than any photographer Ive seen....love the rolling shots. How do I get in contact with him.
Hey Chis Fatseas PM'd me on club highrollers.. i have been told they look for feature cars on the sight and contact Hunzi if they are looking for new cars to feature!
https://www.sau.com.au/forums/topic/207763-51pry-is-famous/#findComment-3680105
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
