Hey guys firstly hello, my name is Simon, i live down south and have just bought my first skyline! :D
Some of you may have know my last car 'DARE YA' the orange Magna, which i sold just over a week ago now!
So this is my new car and is just how i bought it.
Skyline R33 series 2 96'
RB25DET
90,000ks
Manual
208.3kw atw ..... oh and its on stock boost 8psi!
HKS 2540 large turbo
large front mount cooler
twin piped stainless dump pipe into 3inch exhaust into twin rear straight thru mufflers
Remapped ECU (Speedlabs Jeff)
Apexi Power intake
Bosch 040 fuel pump
LED tail lights
Lowered hard suspension
SSR professors 18inch 3 piece genuine 245f and 265r
400r bodykit
12inch percaso sound stream sub with pioneer 760w 2ch and pioneer hu and spreakers
really only looking at putting a dual stage boost controller on it as im pretty happy with the power its putting out atm
Well im hoping to catch up with some of you guys around the place and get to know a lot more about the turbo scene :D
cheers
Simon
https://www.sau.com.au/forums/topic/207924-new-member/
Welcome mate.
Can i ask what you ended up getting for your magna?? that was a HOT car...
SO will your skyline be turned into a show pony to???
lol
hey thanks guys,
ill have to have a look what time the dyno day is etc! ive sorta got the day off lol.
yeah i got a little less than i wanted but i took my plates and nos off! i got 16.5k
this car im trying not to touch too much but i know i wont be able to resist :D
https://www.sau.com.au/forums/topic/207924-new-member/#findComment-3677553
welcome mate, car loos clean as and good power too. Just a question, are those photos of car in current state, just cause that kit doesn't look like a 400r kit.
thanks, yeah thats it after a few hrs cleaning and polishing,
not too sure on the kit im just goin on what i was told from the seller lol
i thought that the rear was a nismo or something like that
https://www.sau.com.au/forums/topic/207924-new-member/#findComment-3677881
haha hi Simon. So ur the one thats been going past my place in the silver skyline. I live just out on elizabeth rd, just down from ur mate that owns the little maroon lancer with the grey front bar, guessing he is a friend. Seen ya go past monday night and sunday arvo i think it waz. Ya car sounds and looks awsome :D
https://www.sau.com.au/forums/topic/207924-new-member/#findComment-3678250
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
