what are the benefits of retaining the VCT? and is it as simple as removing that section of the gtr plenuming and welding the gts-t part on?
only benefit i see is cost. i.e it costs a fair amount to change to a solid lifter/cam setup. but then you have a huge selection of cams to chose from
i dont really want to go explaining exactly what needs to be done on the open forum, however purchasers will be told exactly what to do and whats needed
thanks for the reply :thumbsup:
i understand not wanting to make everything public :D
If my j-spec supplier doesn't work out i will be getting in contact with you for sure ;)
again thanks for all the helpfully reply :)
Edited by [Michael]
Wouldnt recomend the rb26 set up on a 20 head.
Why? Not enough airflow?
Shane and I have spoken a bit about making one for the 20..... Im hoping this isnt an exercise in money wasting....
Edited by R31 drift pig
That's right, not enough airflow for it to make decent response and stumbling on throttle openings. The velocities of the air are what is important. But for the cost, just setup a custom 6tb intake.
Call Wayne at Meridian Motorsport in Melbourne. He can either organise the setup or put you in touch with someone who can.
why is there not enough air flow? cause the 20 heads have smaller ports?
Been lurking for a bit, but now I am finally in the position to get some wk done to the car. I am very interested in the ITB conversion for my (RB25) RB30DET. Is there any (signiciant) difference in ITB designs throughout the RB26 year models that I should be looking for? I have done a search, but came up empty handed.
I already have the Greddy intake with the Q45 TB, but on my '77 280Z that manifold angles out too far and for the most part hits the fender. The GTR manifold would pretty much perfectly line up with the openings in the rad support to the FMIC. Plus the extra throttle response wouldn't suck either...
through i give an update on my situation.
After searching long and hard i finally found a brand new Blitz Kit :P (found on yahoo auction) price was too good to pass up :(
my gtr plenum comes this week and hopfully the blitz kit will be here within 5-6days. i put some pics up of the kit once it arrive
I have done the sums many times for many people, no matter how I work it it ALWAYS works out cheaper to sell the RB25 cylinder head and excessories and buy an RB26 cylinder head. By the time you do the inlet manifiold, cams (RB26 cams are always cheaper), pulleys, bypass the VVT, lifters, valve springs, valves and then injectors (top feed are always cheaper), the fuel rail (the standard RB26 rail is good for over 650 bhp) etc etc.
Then you have the fact that the end result (of a hybrid RB25 cylinder head) is never as good a full RB26 top end.
Cheers
Gary
I havent looked at the 26 plenums in detail... but couldn't you just plane off say 5mm from the first components that bolt to the head (do the throttles bolt directly up to the head on a 26?? I had a feeling they have a small manifold piece between the head and throts...), and get a 25 flange laser cut out of ally, and weld onto the planed off area? That would seem like the most simple, and cheapest method to me... mind you, i haven't looked at the 26 and 25 inlets in detail...
Laser cutting ally is cheap as... hell, take the laser cutters a new gasket for a 25 and they'll be able to cut you an ally flange piece of piss... (ie. used as the stencil)... it might cost you what... $100-150? maybe less (for the flange)... welding it would be the more expensive part, but even that should only cost a couple hundred at most... (welding + grinding the inside ports clean)
Maybe im heading off on the wrong track here, but I just haven't had time to look at the two inlets in detail...
Cheers
Gary
You mean like this??
http://www.skylinesaustralia.com/forums/R3...-E-t207769.html
I'm going single throttle body with the GTR plenum welded to stock runners, hopefully it turns out alright :down:
That's a head setup worth grabbing. 1800 with freight say. A little skim and lap the valves and bingo, bolt right on. Covers and all. Might just grab it myself.
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
