Thanks Geoff, its certainly something ill look at later. To be honest, i cant see why the 0.82 didnt work well previously, however, i do have faith in my tuner. Theyve tuned some pretty serious cars, and have an in depth knowledge of all things Autronic.
For now ill just drive it and enjoy it. Im sick of having the car on stands!
I finally got the car registered today; no thanks to the RTA.
It passed the engineers inspection, i got the Blue Slip done, went to the RTA to pay my rego (last week), and they said the computer has "randomly" selected your car to undergo another inspection at the RTA at West Gosford. Oh, and you also have the pleasure of paying for it! I was soooo pissed off.
Anyway, that was last week. I had the inspection today and it passed no worries. I was treated like a criminal by the rta inspectors though; they showed me no respect what so ever. It was an awful experience.
The lesson is: DONT TAKE YOUR CAR OUT OF REGO WHILE DOING MODIFICATIONS!!
I did a few hundred k's in it today, and ill have to do something about the exhaust; its way too loud. It drones really badly. Its a 3.75 inch trust TR drag exhaust. Im not sure whether to modify it by putting an offset muffler in it (it only has one rear muffler), or buy a 3 inch kakimoto or something thats quieter.
Any advice people??
Shaun.
sell your exhaust and contact Ben at racepace for one.
  • Replies 60
tuned my car earlier tonight, i used the .82 housing. made 320kw on 20psi.
best thing was the 10 psi at 3000rpm and 20psi at 3500rpm, gained about 1000rpm response over old setup. its awesome to drive!
That sounds heaps better than mine. I get about 3psi at 3000, lol. So how similar is it to mine? What compression, what manifold, what wastegate, etc.
They reckon mine will make about 380kw at 22psi, but who cares, its all wheelspin anyway. Id rather a drivable 320kw than mine at present.
Well done.
Who/where are they Paul? Are you suggesting an off the shelf one, or a custom thing.
I just thought it would be a shame to sell the trust in case i want to drag or something. Also, they dont make them anymore. But i could use the money............
Shaun.
Shaun.
I will stick my neck out here and say that Ben produces the quietest mega flow exhausts on the planet...just give him a call
03 9762 9421
Well done.
r32 gtst - rb26
40 thou cp pistons (8.5 comp ratio i think)
jun oil pump
1.2mm oil restrictor and external oil drain
standard head gasket
standard cams
os cam gears (set to 4 and 2 i think)
custom 6boost manifold- duel scroll
garret gt3582r -with duel scroll .82 housing
twin tial 38mm wastegates
wolf ems
i'm going to try the 1.06 housing and play with the cam gears too when i get a chance. hopefully when i get back from this weekends drift australia round.
r32 gtst - rb26
jun oil pump
standard cams
wolf ems
Yeah, thats similar to mine.
The only thing though is the compression ratio. Mine is 9.0:1 and, i might be stating the obvious, but the higher the comp ratio, the more exhaust gas produced, hence, the harder it pushes the turbine. I might be placing too much emphasis on the comp ratio of mine, im not sure, but i was led to believe that my engine may have been spinning the turbine too hard at lower revs for the 0.82, and this was due to the higher than normal comp ratio. Let me know if you thing im misguided.
Also, i dont really understand the dual scroll thing. Is this a turbine housing thats divided into two sections? Would this result in a significantly different outcome to mine? The other thing is the 6boost manifold. Mine is a GCG china one and, although its the best China one ive seen, i think the 6boost ones are awesome. I only saw one recently and was really impressed. Wish i got one now.
You should be happy with your result. It would be really drivable. Ill get mine there eventually; let us all know how you go with the 1.06.
Shaun.
Duel scroll or twin scroll is where the volute of the turbine housing has a divider or partion down the centre of the housing - its cast into the housing. It essentially divides the housing into two rather than a typical open or single scroll housing. You then need to have a manifold made up which groups certain cylinders together and feeds these into each side of the divided housing. The grouping depends on the firing order of the engine as you want to spread the exhaust pulses alternately on each side of the housing.
The advantage of the twin scroll housing is less turbulence = greater exhaust gas velocity = faster spool = broader power band. Because of the efficiency of the housings you can also step up the a/r ratio for better overall gas flow without a loss of spool. The disadvantages are cost and packaging of twin wastegates for a true twin scroll setup.
Toyota used a twin scroll internally gated turbo on their old CT26 turbos which were used in the Grp A 4wd Celica's (from memory).
So you're telling me a non-crossflow Holden 202 red motor has better gas flow than say a 6 litre LS2 or SR20......really?
Just search the web and you'll find more infos on twinscroll, there are better places to invest the money on a straight six engine then on an twinscroll setup. :whistling:
Just search the web and you'll find more infos on twinscroll, there are better places to invest the money on a straight six engine then on an twinscroll setup. :banana:
Love the way you sidestep your "gas flow theory" and then try to talk around it by mentioning the cost of the exercise. Sure I understand these setups are not for the budget concious uni student but it does work.
Perhaps if you did some searching of your own will find the Supra boys are reducing there spool times by 1000 rpm on the bigger turbos with twin scroll stuff on their 2JZ's......(p.s. there straight sixes).
Edited by juggernaut1
did the ef twin thermo fans fit ok
They didnt fit too bad, but required a bit of cutting the original Ford shroud. I had to turn them upside down (in order to fit) and reverse the direction of rotation because i placed them in front of the radiator, instead of behind it. Obviously the air conditioning is gone. I also spent alot of time sealing the fan shroud against the radiator. Actually, thinking back, it was a pretty big job but they work better than anything else i reckon.
Shaun.
In regards to the loud exhaust, everyone who knows anything has told me that you cant buy an 'off the shelf' exhaust that wont restrict anything over 250kw. Therefore, im getting mufflers custom made to suit. This is what many people have advised me to do.
Im sick of setting off car alarms!
  • 5 months later...
Any updates Shaun? Or did I miss a new thread?
Similiar position for my 26
Rebuilt bottom end, sump extension, fuel & management etc etc..
-bored 20 thou over
-6 boost manifold
-tidied head with exhaust side ported
-standard cams with A/M gears
Just not sure which ar to go for .82 or 1.06?
Leaning towards 1.06, since Im ditching my 2860-7 set-up to go single and want some bulk power and tune-ability in the future
Edited by Tomek
I'd not completely rule out considering going a GT4088R or something of that sort if you're looking at 1.06a/r GT35Rs, the spool doesn't seem that wildly different - and you get the whole twin scroll thing going on as well as a fancy big whistley turbo :P I know I'd prefer a GT40R, though I like big turbos and I cannot lie.
I'd not completely rule out considering going a GT4088R or something of that sort if you're looking at 1.06a/r GT35Rs, the spool doesn't seem that wildly different - and you get the whole twin scroll thing going on as well as a fancy big whistley turbo :w00t: I know I'd prefer a GT40R, though I like big turbos and I cannot lie.
Going .82 now ... Lag :wacko:
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
