Not the GTR!!!!, will be very hard to get a better gtr stock than you have now.
Dont do it Michele, you'll have a very hard time finding a neater GTR than the one you already have...
Awww guys, you're making it hard for me. I thought this V Spec II looked clean, but I've only seen photos so far, so maybe you're right, maybe they aren't that easy to find them this clean. Actually, I forgot how hard it was to find this one in such good condition.
I'll send you both the link to the one I was looking at via PM and you can PM me back what you think
any further details on it?
Its pretty stock, very good condition, imported June 2007 - It has 68,540 kays on it now. Mechanics said they believe they are original kays but like the rest of us, I can't always be certain. Has Tien coilovers and a basic boost controller, not much more that I can think of. It has a custom built clutch from KB Engineering Penrith.
I have to be honest, I'm having second thoughts now I look at these photos again and hear what the guys who know my car are saying.
http://i24.photobucket.com/albums/c29/Spri...24-8-07118w.jpg
http://i24.photobucket.com/albums/c29/Spri...24-8-07117w.jpg
http://i24.photobucket.com/albums/c29/Spri...24-8-07116w.jpg
http://i24.photobucket.com/albums/c29/Spri...24-8-07115w.jpg
http://i24.photobucket.com/albums/c29/Spri...24-8-07113w.jpg
http://i24.photobucket.com/albums/c29/Spri...24-8-07112w.jpg
http://i24.photobucket.com/albums/c29/Spri...24-8-07111w.jpg
I wouldn't part with it unless I thought I could get something better, but perhaps I am being too hasty and should think about this harder.
Thanks for knocking some sense into me :)
nooooooooooooooooooooo!
don't do it Michelle. if the rest of it is as good as the engine bay that car is a keeper. original and straight R32 GTRs are a real treasure and everyone appreciates them.
imho moving to a V spec isn't worth the hassle unless you have found one that is as good as yours and a VSpec is a must have for you.
I should also mention, that I had promised Dereck from Fifth Gear Motorsports first dibbs on the 4dr GTST. But can't get him on the phone to let him know I've decided to sell it.
damn..hopefully he pulls out.... :P
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
