  • Replies 55
God damn this is still for sale... Every time i see this car driving i can't help but feel jealous lol
I haven't seen this thing race since the fresh motor went in...
Good luck with sale dude, it'll get sold one day
Thanks mate, i haven't raced it since the new motor.
  • 4 weeks later...
Mate. This is a f*cking amazing peice of hard work!!!!! How someone could build this and sell it is beside me. I do understand because getting a house is important but this is the biggest keeper ever.
Mate Well done and GL with the sale.
  • 2 months later...
From the amount of work you're putting into to this $$$ wise to sell it... it feels more like you want to keep it (and you should!) this car is AMAZING!!!! :D
Excellent work!
Thanks mate, it will be sad to let it go but a new project would be nice.
lucky new owner
how much did u end up lettin her go 4?
Sold for $38k
I just bought the latest HPI to check out this beast. Congratulations Tristan. It looks brilliant in the photos.
Very nice feature, it took a while but you finally got a taker. Be interesting to see yor next project dude
Thanks guys. Currently looking at a supercharged celsior or a stagea with a R34 GTR front conversion for my next car.
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
