ppl i need some help asap ill throw $50 cash in to the person who solves my problem
today driving the car running sweet loving it
after a while i stopped turned it off then started it again and it started ticking
the lifters are not getting oil ???
this has happened before but when away thought nothing of it
could it be when the oil heats up?
the bottom end is fine..
ppl i need help asap.
i dont know what oil is in it cause the mech changed it ill try and find out
hhhhheeeeeeelllllllllppppppppppppp mmmmmmmmmeeeeeeeeeeeee $$$$$$$$$$$$
Edited by teazn_r33
https://www.sau.com.au/forums/topic/208319-no-oil-getting-to-head/
  • Replies 43
Lifters sometimes get dirty and dont work properly. This can cause them to be a little bit noisy... Its quite common in skylines.
Sometimes a few good oil changes will quiten them down. I have heard of cleaning agents which you can add which also help with the process. And make sure the oil you buy is a good quality one.. as the good ones usually have some kind of cleaning agent in them as well.
You can always buy another set of lifters. Not exactly sure how much that would set you back tho.
Edited by br3ndan
this is more than noisy
this is f*#king shit
i still have oil pressure i think to much it use to sit on half way but now its like 3/4
also this is the second set of lifters
and the thrid oil change
I think the viscosity of the penrite 15 is somewhere around 15W 60?
The first cheap thing to try would be to run a thinner oil... somewhere closer to 5W 30 since DOHC heads need more flow to the head..
Edited by MintR33
Your oil pressure shouldnt be at half way if its just idling. Should be sitting on roughly 2. Under a bit of pressure it should b around 4.
I wouldnt recommend using penrite pro 15. THe cold weight seems a bit high for a turbo engine.
Maybe try a different type of oil in your car?
Maybe Mobil One or Royal Purple?
i would not use 15w - 60
Should be more like
5w-10w for the cold weight.
40w-50w for hot weight. However if you engine is new i.e been rebuilt, i would opt for a 30w oil. But if ur engine is getting old go for 40w-50w
is that safe?
yeah it is, most engine flush smells a lot like diesel anyway.
Some people drain all the oil and pour 5L of diesel in there, but i personally dont think that there is enough lubricating properties in diesel to do this.so just add some diesel, run it for 5-10 mins so its nice and hot then drain it out.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
