At the risk of being flamed here's my car on 20's for show
more pics: http://www.mswt.com.au/gallery.asp?thisind...E+NISSAN+R%2D33
its good for show. But not the best fo handling and ride comfort. Hence why I have the below lmgt4's as my daily's :laugh:
  • Replies 143
nah, i chose suspension integrity lol
dropping ur car to the floor is so try hard, biggest rice mod i can think of.
If you insist. :yes:;)
My car is very low (maybe 2 inches off the dec), but most people are surprised what kind of suspension setup I have in it and it's hasnt been thrown together, it was all picked to perform.
Silk Road / Section RMA-8 coilovers (10kg/8kg prog rate with helper spring) with PROPER 8 point dampner adj.
S13 Hubs, Knuckles and stub axles on standard R31 LCA's
R32 front calipers and R33 Non turbo rotors
VS commodore rear calipers
Bendix ultimate front pads, Bendix advance handbrake pads
Cusco tower bar
3rds Productions Rose Jointed Adj. Castor Arms
Whiteline F+R sway bars
Noltec Adj. panhard rod
Driftshop S13 roll centre adjusters
Ikeya Formula steering rack spacers
Alloy steering bush
Urethane gearbox mount
Super-pro bushing all through car (Trailing arms/swaybar links)
7 point rollcage with rear tower bar built in
Ill also be putting a R32 steering rack in in the near future to get even better steering
Ive owned a R32, a S5 and 2 x S3 RX7's a 180 SX, a S3 R31 import (IRS) and another Aus Del 31, and out of all of them, my 31 has been the best performer. Sit's flat, and is very responsive. Has great grip (10 inch wide rears help) but is VERY easy to coax into a slide. I raced Karts when I was younger, and my dad has raced since he was very young (both cars and Bikes) so it's not like we stick china coilovers in and think it's the greatest thing ever.
Im not going to jump into the SK groupie bashing like everyone else does on NS.com, as Ive been a 33 with a full SK track setup, and it was brilliant...
But maybe commenting on a cars suspension integrity should be kept to yourself. Ill have to take you for a skid lol.... on the track of course.
Edited by R31 drift pig
Do you have any side-on pics?
Have to agree though. Definatley managed to pull 20's off. Look really good wiht the paintwork. Me personally Id lower it a tiny bit more, but you'd probably kiss the kit goodbye in a week LOL
What colour is that BTW?
Thanks
They pegasus rims. No mods to fit, but they rub on the inner guards so might remove them.
The colour is Mercedes Cubanite silver (more a champaign)
I'll dump it if I ever enter it in a show but won't go lower than this for every day.
pm me if you want anymore pics :cool:
its good for show. But not the best fo handling and ride comfort. Hence why I have the below lmgt4's as my daily's :cheers:
Those 20s look awesome,what body kit is that on your car?
you see now his daily wheels are absolutely sex! thats exactly how a skyline is meant to look
really good job on your 33!
chrome 20's belong on some gangstas 4x4
If you insist. :cheers::thumbsup:
Cusco tower bar
Alloy steering bush
haha yeh, im running SK's GB, but ill be the first to point out its not perfect. but i have to say im very impressed with how it performs, looking at 3kg spring rates, you would expect it to roll around a fair bit, but it just doesnt, it sits as flat as most coilovers ive driven on, and the same as mates with cheap coilover kits such as ISC and HSD's with 8/7kg springs, yet without the shit dampening.
dropping the car ridiculously low is pretty bad, i mean id only call it a real ricey mod if your doing it for looks, if your doing it for performance, well, i think youd be hard pressed to prove that point when every bit on information available in credible articles tells u otherwise. but if it works then great, i just think people often confuse a lack of traction with being good for drift, i see a lot of people in KE70's and R31's dropping the car on their arse and running 175/60's and sliding all over the place and then wondering why they cant qualify in comps.
not having a go, i just personally like to relate proven settings and information towards racing etc to drift as well. it comes down to preference in the end.
the daily's look so much better, as much as for some reason im skeptical they are GT4's. seems in ur thread there is similar doubt. only reason i have doubt is the first thing that struck me was the angle and concaveness of the rims, for the offset they are the usually pretty much straight, it is only the wheels with around +22 or less that feature a noticeable concave appearance. also with that concave shape, with a GT4 it is a more smooth curve, rather than a straight spoke pointing out then sharply coming back in, similar to what is seen with Koya drift teks, URAS NS-01's, DT-05's etc.
also the spoke shape is different to what id expect, the spoke is more angled in, from wide at the middle, to wider going towards the rim/barrel, the GT4 is usually more straight and overall wider.
haha well seems everyones the expert on lmgt4's on here without ever owning any. think ill be taking some pics of the badging on the inside soon.
the fronts are flatter. the rears are 9.5 wide. hence the more agressive angle on the spokes. it doesnt just depend on offset.
My silk roads are some of the best coilovers to come out of japan (even though they were probably made in taiwan or some shit), they dampner adj. ACUUALLY works, and is a simple 8 point, not a fully sick 36 billionty way. You can seriously feel the difference between point 4 and point 8.... Ive had Tein, JIC, HKS, and custom made, and these by fare are the best.
The ride height was also a by-product of changing to a S13 setup. A S13 coilover at full extension ie. wound to max height will actually drop a 31 30 - 40 mm..... My Front coilovers are only down about half way, and are fully captive even at full extension, and my rears are a little lower. The kit also makes the car seem lower than what It actually is too.
I dont have a massive lack of traction, the thing actually sticks like shit to a blanket. It was built as a circuit car, then modded to suit drift (alignment changes and spring dampner settings).
I run 225/45 R18's on my 10's, so enough tyre getting down. Id love to go wider when I fit my TD06 in the next few weeks, but I simply dont have the room underneath those guard lips.
All of this being said, the 31 is still a largely untested car, and I dont think Ive realised it's full potential.
Yet the one vital thing, which no matter how good the car is, will make it or break it - The Driver. :D
And as a side note, I run 205/50 R15's on my KE70 LOL..... Be even better when I change to my 15 x 8 -4 wheels. But with a 4K 1300cc powerhouse,under the bonnet, I aint qualifying for anything LOL.
:D
It's nice not to have a screaming match like on NS.com about suspension for once.
And Liquid Ice, I had another look at those pics, I really like those wheels. You'd be one of the only ones to pull of 20's in my eyes.
And look how quick this shit is gonna catch on.... the japs are sticking 19's and 20's on Z33's/V35's/R35's all over japan, soon enough they'll be everywhere.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
