Item: GT3040 0.63 rear 0.7 front, turbo kit, stainless manifold, Tial 38mm wastegate, braided oil + water lines
Age: prob only 5000km
Condition: like new
Price: $2500 ono
To Fit: (What car) RB20. RB25
Contact: 0431257754
Comments: only ever run 13psi with few short spurts at 17psi. includes polished intake pipe and K&N filter
Item: Microtech LT12s plug n play computer with hand controller
Age: 5000km
Condition: like new
Price: $1000ono
To Fit:RB20DET
Item: EBoost 2
Age: 5000km (if that)
Condition: like new
Price: $500
To Fit: anything
Item: RB25DET built motor by RACEPACE
Age: 10000km
Condition: excellent
Price: $3500
To Fit: anything
Comments: aries pistons, RB26 rods, N1 oil pump, tomei cams + gears, metal head gasket. everything done. have dyno sheet for only 285rwkw. could handle lot more
Item: 19 row oil cooler and filter relocator
Age: 5000km
Price: $250ono
To Fit: RB20
Comments: all braided lines, anodised
also large front mount, full set of autometer sport comp silver mechanical guages, oil pres, water temp, boost and monster tacho,
720cc siemens top feed injectors with big rail to suit rb20det with speedflow fittings $650ono
bosch 044 fuel pump, 1.5L surge tank
throttle body, coilpacks, heaps of other little things
selling everything... make an offer. will post at your expense. im in adelaide
no time wasters. all must go. need the room
leave your email if you want pics
adrian 0431257754
i not on here often so call or message
Edited by VLT020
ok. everything was sold but has fallen through so its all up for grabs again. selling whole car so make an offer on anything. best i dont check this often so call or message on 0431257754 or [email protected]
hey man is this all for this price
pics would be nice
and have the injectors been flow tested and cleaned or are they brand new
    • Yea that's a fair assumption. I'm presuming they call them solid lifters as they have no moving parts like hydro lifters.
    • I believe you're confusing WMI with water injection. Looking at that graph, the 93aki+WMI car is making more power than C16 race gas. Boost juice, which is what I also run, is Snow Performances 50/50 premix.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
