Hi guys,
Just ordered a HKS GT2835 Pro S from Greenline for my R33 GTS-T and I was wondering what sort of torque figure I should be expecting with it.
Yes I've done a search, and looked in the dyno threads and I couldn't find any info regarding torque output. Here are my mods (well, will be in about 2 weeks time):
GReddy Front mount I/C
SplitFire Coil Packs
Power FC
Straight through 3.5 inch exhaust
Pod filter with custom Cold air intake
Bosch 040 Fuel pump
Nismo 555cc Injectors
HKS GT2835 Pro S Turbo
Z32 AFM
Running 17 PSI
I know I should see about 250 - 260 KW at the rear wheels by looking at the RB25 dyno threads, but what about torque output?
I am sure most of you know that torque wins races, not kw. So, any ideas?? Has anyone with a HKS GT2835 Pro S actually had their torque measured?
Hoo roo
Cool thanks..
Not too happy but, I found out that a 2008 Holden CLubsport has 550nm of torque at 4400 rpm, the graph in the link you sent only has about 520 nm at its max.
Does this mean that a standard clubbie would beat a GTS-T with a HKS gt2835 pro s?
a well setup GTST will take down a new clubsport no problems
lots of things come into play when going against another car
diff gears also play a big part - you'll be fine
i was able to take down a 2000 ish model R8 297kw ute with my 200rwkw and stock turbo and well setup GTST
the specs are here http://www.highperformancetrucks.com/truck..._view.php?id=48
They say there that the 0 - 100 km/h time is 5.1 secs for the maloo ute, would a skyline with my above mods be quicker than that?
cheers
yeah should be - i managed 0 to 100 in 4.88 in my gtst with a perfect launch and good tyres
that was with the rev speed meter and g sensor kit so it should be reasonably accurate ish
your reading too much into specs and numbers on paper dude
dont stress the car will be very fast on the street
even with the std turbo and a good setup the gtst is a pretty quick car
Yeh, trying not to stress, but when you spending thousands of dollars (nearly 12K I've spent now with the mods I have) you want your car to be quick as a rocket and have power outputs to come with it.
When I got my car dynoed the first time (pulled out 202 rwkw with standard turbo and PFC) the tunner told me its not about KW, its about torque. Now I know the new clubsports are a fair bit heavier than an r33 GTS-T, but their torque is crazy, 550nm at 4400 rpm!
I noticed that link above with the dyno sheet by sly33 managed to get like 280 rwkw but only like 520 nm of torque, does this mean that a new clubbie would beat a GTS-T with a HKS GT2835 Pro s sicne it has more torque?
WHen you measured that 4.88 0 - 100, was that with the standard turbz?
With the mod list you have and a good tune believe me you will slaughter a hsv. You turbo choice is damn good for a quick response streeter. My bud has a very similar setup and runs low 12's on the strip. More than enough to take care of most of the v8's you will encounter.
as i said stop reading into the figures and just drive the car when its done
be sure you have your suspension sorted out otherwise youll struggle for traction
yeah my 0 to 100 was with the stock turbo
Of course they're going to make more torque... They're a 6L V8 after all. :D
Think of it this way though. They have 297kW, you will have 325ish. (Flywheel) They weigh 1800kg, yours weighs 1370kg...
Yes but I weigh 120 kgs.... lol
So you're saying, even though they have more torque, I will still be able to beat them merely because or the weight of my car (being less)?
as i said before - lateral acceleration and weight is the main factor here
dont read too much info magazine plotted numbers and graphs etc.
the gtst will run 4.11 diff gears and weight less - so it has more rapid acceleration
the r8 or whatever probably has taller diff gears (3.7 ish) so less acceleration, more top speed and weighs more
so on the dyno plots it looks the same or stronger but on the its a different story
look into a diff cradle kit to stop axle tramp
look into some better tyres
but try it once the turbo is fitted and tune is done etc
then see if you need more traction etc- i bet you will
I've noticed the insides of the rear tyres are wearing out heaps (probably about the inner 15%)
So, what tyre size should I get, 235?
WOuld it matter if I got 235 on the back and 225 on the front?
go see a suspension place about the tyre wear
you need some camber to align it properly
youll need a diff cradle kit to stop axle tramp too
some bushes will probably help with handling too
most mild gtst's go for 255's on the rear
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
