hey i dont know if this is the section or not but if its not please move..
i had my car on a jack and was taking my front wheels off when i noticed alot of play in the wheel..
like movement left to righ up and down..
now coz my car is defected it wont pass inspection so im wondering wat i need to do to fix it..
i have herd wheel bearing mentioned.. would this be correct?
its only the front left wheel... i have had all the control arms done and bushes and stuff..
any ideas?
cheers adrian.
https://www.sau.com.au/forums/topic/208675-what-would-be-the-problem/
any noise when u driving and applied load to those side (turn left)
if yes, could be wheel bearing.. they are inside the hub, need special tool to press them out and replace with the new ones or buy used hub from wrecker (u dont know the condition of the used ones)
all up to u.. I've got a quote for $300 to replace the front left wheel bearing (drive in drive out)
hope this help
If your bushes and suspension rubbers have all been replaced then its definately a wheel bearing. If its that bad your wheels going to fall off soon - mechanic shouldnt of let it out of the shop.
If you turn the wheel all the way to the left or right and hear a big clunk whilst going over corners/bumps etc. its your balljoint - you really need this to steer otherwise the wheel will be flopping about, probably fall off also
Both are really cheap and easy to fix. Get a balljoint & balljoint tool and a wheel bearing kit from supercheap etc. If in doubt replace them both
Edited by Jmaac
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
