[group Buy] Acpt Carbon Fibre Tailshafts Any Model! $1400us
  • Replies 717
do i take one for the team and ring ACPT....... OK I will. Need your details and what shaft Willo and MR Keets so i can ask them personally where it is and what the tracking number is etc etc
if he was sending them out that day there should be tracking numbers with it..
i'm not getting any replies from any of them at the moment. still waiting for the numbers on the shafts and who's is what.. i have a big mess here to sort out, but hopefully its just the 32 2000 models all mixed up which will make things a bit easier..
Merli, let me know when and where also :P
Ok, officially pissed off to the max after this morning at both 1 am and 6 am. The thing hasnt even been finished when they said it had! James UNFORTUNATELY is sick at the moment, he apparently gets copious amounts of emails and hence why we wonder why no response. My shaft is still getting balanced. So still dont know when it will be sent off, now for the others who have no shaft i cannot tell you anything as i didnt have your details, but i would assume that you would be in the same position as I.
Another note, the woman who i spoke with who takes the orders stated that the shafts were PREMADE, meaning when the order was placed yonks ago they had the base shafts already in stock in shelving. i.e stock 32 33 34 shaft lengths... Which makes me think what a bunch of (unts for delaying everyone for 4 months etc when it was already ready to go.
Anyway, will let you know if anything else comes to light, they really are slack over there and dont pull their digits out often enough.
If my driveshaft hasn't been made I want my money back. I am sick of waiting and the money can be better used elsewhere. If the shaft hasn't been made there should be no problem getting a full refund as it hasn't cost ACPT a cent yet.
Andrew, organise it with StS or ACPT or whoever to make it happen.
Hey Mate,
do you mind waiting a little bit longer till we get actual word from James?? I understand the issue and hopefully it can be sorted out.
tho if you still wish to drop out? any chance we can find another person to jump in place??
after reading what 34tomidnight wrote is crazy. what a f**k around. tho everywhere where i read to order these shafts there is always a 6 week wait??
Hey Mate,
It has been over 19 weeks since I paid and 16 weeks since the order was placed. If I don't have a driveshaft or at very least a tracking number by next Friday I want my money back. That doesn't mean ACPT telling you it was/will be sent on whatever date because clearly these assurances are empty promises at best or straight out lies at worst.
whats it for mate if you are close u can have mine & i will take yours when it arrives.
Not in a hurry to put in just yet.
Dont stress m8.
Nothing either.
i talked to Paul the other night
no body's herd much since James isnt there.
it is only 3 left we're waiting on.
Willo, 34tomidnight, and Mr Keets..
Edited by Angus Smart
I was wondering if you guys had heard anything yet.
Makes you wonder why he has that many..
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
