Make: Nissan Stagea Autech 260RS
Model: Stagea Autech 260RS
Milage: 115,000
Transmission: 5 speed Manual
Colour: Pearl white
Complied? Yes
RWC supplied? Yes
Currently registered? Yes
Price: $40,000
Contact: PM
Times up, missus wants a Prius. Hell of a way to reduce my carbon footprint.
97 mod. Excellent condition. Motor completely rebuilt at 100,000kms.
Engine.
RB26DETT
K&N pods
Z32 AFMs
N1 Group A turbos (RS581's)
TuneAgent manifolds
HKS dumps
Nismo front pipes
Trust PE2 exhaust
Blitz FMIC 102mm
Just Jap radiator
Greddy top pipe (rad)
N1 water pump
N1 oil pump
Oil catchcan
Tomei HG
CP pistons
REV I beam rods
Fully rebuilt bottom to top
New valves, stem seals etc
Minor head work
Tomei 264 cams
OK Giken cam gears
Greddy timing belt
Greddy timing cover
Relocated oil filter
Oil cooler
Tomei sump baffles
Sard 700cc injectors
Greddy rail
FPR
Bosch 044 pump
Splitfire coils
NOS heat plugs
Direct clutch twin plate (very heavy)
RS*R coil overs
Brembos with Ferodo pads
DBA5000 slotted rotors with gold hats (replacement rotors are cheap!)
BEO gold 17"
Greddy oil pressure guage (elec)
Greddy boost guage (elec)
Greddy pillar mount for the above
PowerFC
Greddy ProfecB Spec2
Blitz FATT timer
JVC HU with 3.5" screen
Im not sure if I have forgotten anything.
Car has run 11.9 in Darwin, unprepped track, street tyres at 35psi and 30deg heat (wind was blowing the wrong way too).
500.9rwhp, once again 30deg at 22psi. (wind was ok this time).
Regularly serviced, rarely driven as I have a Lib GTB wagon for work and the missus wants a Prius.
Great fun to drive, attracts very little attention. Manages to scare most people silly.
PM me for any questions.
Cheers
Ken
https://www.sau.com.au/forums/topic/208727-autech-stagea/
  • Replies 157
That is a sexy list!!! good luck with the sale and the errrr prius!
Guys picture doing those mods to a R33GTR and what do you get? An awesome vehicle!! this one has bootspace!
free bump.
https://www.sau.com.au/forums/topic/208727-autech-stagea/#findComment-3705348
RBNT, i already have a manual S2 stagea (neoRB25DET) and i can vouch for the cost of setting up something simpler than you have.
i can also vouch for how good these cars are when they have been set up with this much care.
this is a bargain and i would be thrilled to be in the market right now.
https://www.sau.com.au/forums/topic/208727-autech-stagea/#findComment-3729791
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
