it is an aftermarket steering wheel, came with it though and yeh ive had a wheel allignment recently but it has done it since the day i got it... as i said it doesnt seem to affect anything...
i will check the fluids as mentioned above.. see what happens..
if you have aftermarket steering wheel forever, and the light comes on after a while without turning corner, forever, it is almost certainly the steering wheel on crooked.
find a straight flat area, drive a couple of m, take the steering wheel off at the big nut, put it back on straight. should fix the problem - hicas throws an error when your wheel is crooked because it thinks you have been driving in circles for the last 20min
how long are u driving in a straight line for?
on the older model's the HICAS ECU picks up that the car is going at speed but because it's in a straight line the ecu get tricked in to thinking that there is no signal or false signal from the steering angle sensor so it turns of the HICAS system to be on the safe side. not a major problem but still a problem. sorry but i can't remember any fixes for the problem. try looking on UK forums they have a lot of straight hiway/roads an i have read that a few people have found a fix for it
hope this helps
well im gunna try what Duncan posted above on the weekend,
but to answer your q neofenrir34 its literally just when im heading along a highway, as an example and im not sure if you know but say if i get on the bruce highway and start heading towards the sunny coast from brissie then within 5mins of driving along the highway the light will come on...
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
