Item:Hiper Gear TR43 Turbo, Tial 38mmExternal Gate, Custom Manefold for rb20, GTR injectors
Age:about 8 months old
Condition:very good
Price:$1000 Quick sale!(will separate for right price)
To Fit:RB20 ..... come off R32
Contact:0433663833 for fast reply dont get chance to check this site to offten
Comments:Gear still in working order only come off car as going for 1jz power and found motor with all the bolt on's already
Pic's coming!
Thanks
(Just for Boosted 32 as he need hes hand held)
ofcourse you need more then just these mods to get to 300rwkw but hiper gears website reads this turbo is able to help your motor get to that power.... you will run around 220 rwkw with these mods a cooler and retune....
Edited by evlgtr
300kw for rb20det....Id like to see that, got a dyno chart to back that up?
.... saying the turbo is able to suport that power buddy...... as per there web site ... i was only runing 16 psi making 220rwkw with this setup (and cooler and retune) but with the right engine mods the turbo is ready to make that power so go pull urself off in someone else's thread.
unless keen on gear keep it to urself.
Edited by evlgtr
mate has one of these turbos.. car has plenty of torque on his rb25.. Good asking price :D
Edited by LTHLRB
I may be interested if you can show me a dyno sheet mate, id like to know how laggy the turbo is, when does it hit 16psi in say 2nd gear?
Also how much would u be after minus the GTR injectors?
wasnt being smart ot trying to wreck your thread! maybe u should think of how u word things before u post! I would still like to see some proof that these turbos will support 300kw
Developed for: SR20DET, RB20DET, RB25DET,RX7 or any other 2L or bigger engines. It is Rated at 440HP fly wheels standard ,or 500HP High Flowed. This turbo is good if you are chasing high top end and good responds. External Wastegate might be needed on engine sized 2L+ or high performance applications.
This is a high end performance turbo. The turbo responds is from about 2000RPM depends on engine type. This turbo is designed for track, Drift and drag racing. The max recommended boost out put is no higher then 20PSI.
This is from the turbos website.
