Shaun @ All Star
Unit 3/21 Vale Street
Malaga, Western Australia 6090
Ph: 08 9248 7433
they got very good results from my friends turbo honda, Shaun spent the extra time to get the tune right, and he was more than happy to spend more time on it once my friend had taken the car out and driven on the street and found some issue with the vtec and the turbo.
Shaun also tune my car with A+++ results (powerfc) and if i didn't already have a pfc i would be going down the ultimate path as in my opinion it is a far better ecu that the pfc
Edited by [Michael]
i think the question should be who tunes e-manages WELL
hyper drive told me to stay away from them cos they cant get good results
and they are a greddy dealer
but i dunno i haven dealt with allstar
so i cant say any thing good or bad
let me know how it goes
cos im gonna go down the pfc path but im worried bout the auto box
Seriously you can't put the pfc and emanage in the same category. The emanage is just a glorified safc.
pfc is old and overprice for what it can do (can pay anywhere from $1000 to $1500 for one for an r33) greddy ultimate is far from a glorified safc, it can do everything the pfc can do and alot more. it is very popular in Japan, many cars run it for example d1 s15 running 400-500hp.
if i can be stuffed later i will post up the laist of its spec.
Just because some tuners haven't learn how to tune it 100% and/or find it hard to tune with doesn't make it a crappy ecu
Edited by [Michael]
PFC overpriced for plug n play with perfect driveability?
You can hardly call the Emanage an ECU cos it's only a piggy back system of the standard ecu(just like a safc).
My 3c
Glorified safc? LoL. They're pretty decent for the price, and the amount of stuff it can do. EG: remove afm and run map, adapt to bigger injectors, launch control, remove boost cut, speed cut, bla bla bla. You're still prolly thinking of the emanage blue?
http://www.skylinesaustralia.com/forums/ma...56-t161460.html
Some info.
Edited by KeeFy
Yeah and for those who don't want/need to go down the full blown ECU replacement path, e-manage ultimate looks like a pretty good deal. Any one running extensive mods might want to consider something else, but for the majority of people running mild mods and in need of a tune, the e-manage makes sense peformance wise and financially (given the tune isn't done poorly the first time..).
have heard of a few problems with ultimates on rb's
had a r34 auto with one here , owner gave up and removed
just be careful and do research , find a tuner with proven results on skylines and ultimates and talk to the owners of the tunes
even with an r33 auto I would run the pfc , for what you get there still worth 1500
AFAIK on the R34s the most common problem would be the coils. An adaptor is needed (from greddy) to work with the emanage ultimate, if not it'll fry the coils in a matter of mins to secs.
I agree a PFC is the fool proof way to go about it, but $1500 in comparison to $700+ to $800 is a huge difference IMO. The other thing about buying a PFC now is they are mostly seconds, and if it screws up, well... you know the drill.
Thread through the pages from the link i posted up above, answers most questions and from the results from the drift car, do you rekkon it's another safc bling?
GReddy Ultimate is the second best thing to any full featured ecu.
Is miles above SAFC and other signal benders because it bends 'all' signals, adjust AF ratio... if you could get a AFC 'bender' + timing 'bender' you would be fine.
Ultimate does a lot more than just these two...
I recommended NIStune because it makes stock ecu retuneable and retains stock auto shift logic(as does Ultimate - technically) + retains knock maps for engine protection.
Power FC is second best as it is plug and play, and is well supported... but is rare as/slash expensive as....
At the end of the day, choose your trusted tuner and go with their recommendation.
Edited by infamous_t
how much do did you pay for a tune at tenagah, (if ya don't mind) dealed with them before and they were petty expensive
found out today when talking to him that glen 'Lumpy' camble tune it through them. cost 50 to use dyno and 160 for tune. he said that he has left hyperdrive and is freelance tuning now?
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
