Hi all, i have an r33 gtst and my passenger door wont open i had a mechanic look at it and he said that the latch that actually holds onto the car from the door is most likely broken (its on the second click so the door moves a bit) but he said i will most likely have to cut the door trim off which i really dont want to do, so has anyone out there had any problems with this? any help with be good!
Cheers Scott.
https://www.sau.com.au/forums/topic/209152-r33-passenger-door/
It'd be a very tedious task trying to open the door by somehow hooking onto and yanking the internal latches (especially if they are broken).
Forced Door trim removal might be the only option mate.
Edited by MSPEC33
how about putting the window down and using a metal strip to push whatever it holds on to. Maybe you get lucky and the door will open. A mate's of mine got into the same situation on his civic and in the end the workshop got lucky and they could open the door this way. Turns out to be a bad power lock device thingy. He dumped it so the door becomes a normal non-power locking version.
same thing happened to me, only way is to cut the door trim, and get in there with a screw driver and a hammer and smash the locking mech up till it lets go, very frustrating problem but when you see how crap those locking mechanisms are you understand
this happened to a couple of Kia's I've worked on over the years, we found that the screws that held the lock to the door would fall out and get jammed in a bad place( inside the lock), to get the door open(2 person job) we'd make sure the door was unlocked : ie hold the snipper knob up in the open postion hold both inside and outside handles open, remove workboots find the strongest place on your door trim to give a shove with the heel of your foot and try to jar/force the door open. Don't try and Bruce Lee the thing open as you'll only screw your trim.
Failing that try to pop the end of your trim closest to the lock and see exactly whats stopping it workingyou may be able to pry the trim away far enough that you can get in there without totally stuffing your trim up, hope it works out.
Cheers Matt.
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
