Decisions Decisions
43 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 100
Hehehe... ...If Alex is the older guy... ...then he freaked out my GF... ...He started talking to her in chinese and tapped her on the shoulder a few times... ...She just went red and walked away...
She was a little stumped and wasn't able to let him know she's Japanese... :)
in that situation, or if someone calls you by the wrong name, you should always interrupt immediately, correct and move forward in the conversation because its more awkward to do it the second time you see them :)
oh fkn lawl at nicks coils!!!! the 4door sounds like a cheap hotel bed.
ahahahahah yeah!
every other car sounded tough - and then nicks emo 32 came hobbling over with its squeaks and stuff.....gold
yeh ask dr. drift about selling me coilovers were both rear shocks are bollocksed :/
I was pissed off, I soo wanted a R35 Poster, the Nissan Rep, said no they didnt have anything...bastards!!! then my mate comes over with a bag full of holden stuff, which i quickly dropped on the floor and kicked under some other car, dont think anyone saw me. haha.. another funny thing that happened.. we visted the BMW area, we noticed the guest area was serving beers. I was feelin a tad thirsty. so me and my mates just strolled in and asked for a beer. the bar maid was happy to give it to us 4 crown lagers and 2 coffes. i pulled out my wallet and was told my money wasnt necessary. then she asked if i worked for BMW, I jokingly said I was an engineer or some crap like that. she giggled, knowing full well i was lying. but proceeded to let us stay and have our drinks as long as we left when we were finished.. I tell u what, a beer tastes so much better when its free..
BTW.. anyone agree that the Blue Lexus had the sexiest paint job ever!!
in that situation, or if someone calls you by the wrong name, you should always interrupt immediately, correct and move forward in the conversation because its more awkward to do it the second time you see them :woot:
Yeah... ...I know what you mean...
I was looking at a different car at the time she came running over to me... ...I tried to get her to let him know she's Japanese but she was too embarrassed... ...I also tried to apologise to him but too many people talking about cars so I let it go... ...even though I know I shouldn't have...
I'm sure he heard her telling me off in Japanese for walking away from her and letting her get into that situation...
:D
:D
ouch.....snickers is the only way to get outta that mess sonny jim
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
