Item: 1996 SII R33 Skylines gts-t M-spec (i think)
Condition:broken
Contact: PM me!!!
Comments: Most interior Parts available!!
The car is White complete with front hit, airbag deployed PM if theres something you need but dont see on the list, im unsure on some prices so hit me up!! PREFER LOCAL BUYERS!!
im keeping running gear/brakes... and prefer to keep the car rolling for the moment!
Type M side skirts $160 small crack bout1-2inchs on front bend
Type M boot spolier/boot $200 good condition
Doors: can come complete or minus trims/switchs/windows $offers
Drivers gaurd slight scratch on front tip $100
Seats F/R series II good cond. $170 front $100 rear $250 the set
Door trims $60 each
COMPLETE F/R SEATS N DOOR TRIMS $360
Clear side gaurd indicators $70 mint cond. were ON hold but person hasnt got back to me so back up for sale!!
Rear bar with type M pods $150 1 pod is broken on the inner side cant really see it from looking at the car.
rear reo $80
Tail lights mint condition $70 each
Mirrors, good cond. $40 each
Climate control unit $100
rear garnish 'skyline' $40
Elec ariel $40
theres heaps more bits but i cbf going out in the heat at the mo so hit me up if you need anything!!!
Edited by shy_s6
  • Replies 65
Posted Images
master brake cylinder and clutch slavecylinder?
ill be using these sorry
I need an ashtray and the parts of the boot interior. The "carpet" that attaches to the boot itself and the carpet that goes along the back wall closest to the number plate...
no ashtray or boot carpets sorry
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
