Item: 1996 SII R33 Skylines gts-t M-spec (i think)
Condition:broken
Contact: PM me!!!
Comments: Most interior Parts available!!
The car is White complete with front hit, airbag deployed PM if theres something you need but dont see on the list, im unsure on some prices so hit me up!! PREFER LOCAL BUYERS!!
im keeping running gear/brakes... and prefer to keep the car rolling for the moment!
Type M side skirts $160 small crack bout1-2inchs on front bend
Type M boot spolier/boot $200 good condition
Doors: can come complete or minus trims/switchs/windows $offers
Drivers gaurd slight scratch on front tip $100
Seats F/R series II good cond. $170 front $100 rear $250 the set
Door trims $60 each
COMPLETE F/R SEATS N DOOR TRIMS $360
Clear side gaurd indicators $70 mint cond. were ON hold but person hasnt got back to me so back up for sale!!
Rear bar with type M pods $150 1 pod is broken on the inner side cant really see it from looking at the car.
rear reo $80
Tail lights mint condition $70 each
Mirrors, good cond. $40 each
Climate control unit $100
rear garnish 'skyline' $40
Elec ariel $40
theres heaps more bits but i cbf going out in the heat at the mo so hit me up if you need anything!!!
Edited by shy_s6
  • Replies 65
Posted Images
master brake cylinder and clutch slavecylinder?
ill be using these sorry
I need an ashtray and the parts of the boot interior. The "carpet" that attaches to the boot itself and the carpet that goes along the back wall closest to the number plate...
no ashtray or boot carpets sorry
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
