  • Replies 65
Posted Images
  • 3 weeks later...
Would you consider 100 bux for just the rear bar. Could pick up in early May.
yerp no probs
what color was the car mate.? pm me your number if its white. need many parts
yes its white! hit me up on here with what u need
also for Sale
18x 7.5 maybe 8 unsure, 4 stud pretty normal offsets!
front tyres around 60% rears would be just under legal
heres a pic of the same wheels
after 700o.n.o will need some stockys and price will be reduced with them
greedy style plenum with 80mm billet throttle body to suit RB25 (adapter plate has already been welded on so t/b bolts straight on) $450
White P1 buddy clubs 5x 114.3 17x 8 17x 9 (guessing) goodyear eagle F1's 235 fronts bridgtone potenza re001 adrenilans 255 rear, tyres are pretty much brand new, very good cond need a clean came off a r33, i did want to keep these but dont clear the struts on my s13 (yes i have coil overs but car is going to regency) $1750
i will need at least a pair if 5 stud wheels for my car to roll around on haha
Edited by shy_s6
still interested in rear bumper cover if u still have it.
Don't need the pods or reo tho.
I'll be up that way on the 17th May.
If u need I can bring tools and take it off if you like :laugh:
I'll PM u later for some details etc.
i have tools bud, im getting stuck into my sil project but if i find time ill get it off :D
i need the following.. in white only R33 S2..... Del to melb
Price plz
front bar ( any except s1 bar) + grill
s2 bonnet
rhs s2 head light
rhs lower control arm.
rhs front guard
rhs side skirt
rhs door - (bare) - i have one with a big dint which i will swap you to avoid removing the insides.
rear bar ( any )
lhs rear tail light
rear center thing in between the light.
boot and spoiler. s2
Price plz
front bar ( any except s1 bar) + grill broken
s2 bonnet bent
rhs s2 head light broken
rhs lower control arm. i have
rhs front guard i have
rhs side skirt i have but selling as a pair
rhs door - (bare) - i have one with a big dint which i will swap you to avoid removing the insides. i have
rear bar ( any ) sold pending payment
lhs rear tail light i have
rear center thing in between the light. sold
boot and spoiler. s2 i have
delv will be a prick for the bigger items i think bud, but if you want to sus it from your end go ahead
  • 3 weeks later...
  • 1 year later...
all prices very negotiable guys may sell complete wreck soon as i have most the bits i need!!
need a aerial and some air con bits and probally some other stuff, still parting out?
  • 4 weeks later...
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
