Thanks again guys, really appreciate all the comments.
The car has Nismo shocks and Nismo springs which lower it a bit but nothing drastic.
I've got no scrubbing issues at all as the offsets are quite safe. +24 front and +28 rear.
I'm actually in the process of swapping the wheels out and will more than likely be putting on a set of Bronze TE37's.
Oh, and it's an 04.
https://www.sau.com.au/forums/topic/209702-pics/#findComment-3709625
  • 1 month later...
Nice car. It is exactly what I am looking for. Black, manual with a sunroof. I presume that they are not that common. I have only just begun searching for one but have been told that it would take ages to find this exact combination. If anyone can comment please do so. I have the money but I wonder how long I will have to wait to find one. If anyone happens to see one please PM me.
https://www.sau.com.au/forums/topic/209702-pics/#findComment-3828049
would be difficult to find locally, but if u think money and time is no issue, just source one from japan, and import it here.
https://www.sau.com.au/forums/topic/209702-pics/#findComment-3829346
Hey nismo, G.T.here, what size and offsets will you be running with the new bronze wheels,just curious. By the way, have not heard from anybody that has used STD 350z springs yet, still keen to do the mode but would like the results first, dont want to waste my time if its not going to give me what I want, ILL just hang in there and wait I guess. Regards G.T.
https://www.sau.com.au/forums/topic/209702-pics/#findComment-3830491
Hey mate,
The TE37's I'm pretty sure are +22 all the way around.
It will give it a nicer look, but nothing drastic as at the end of the day you're talking mm's here. +24 v's +22 is 2 mm difference at the front.
Cheers
Bobby
https://www.sau.com.au/forums/topic/209702-pics/#findComment-3831749
  • 2 months later...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
