As it says Apex'i Power FC with hand controler in box and S15 injector package for RB25det.
I am selling this as a compleate package and i am not seperating or shiping interstate and the price is firm
and its pickup only so dont pm me asking me to seperate, negotiate price or ship interstate. because the answer
will be NO!
If there is no problem with this please read on... :D
As stated before i have a Apex'i Power FC practicly brand new in box.
only a couple of months old. the box has been opened and i have run
it in the car for about 30 mins then it was pulled out and put back into
the box until ohter modifications were done and it was ready to tune.
I also have a compleate set of 6 injectors out of a 6spd manual S15.
the injectors are in a RB25det fuel rail and are ready to bolt in.
I also cleaned the injectors, checked spray pattern and flow tested them
at work.
The spray patern is perfect even spray and the injectors flow 480cc.
(off the top of my head i think it works out about 95ml over a 10sec open flow interval)
My plans have now changed and the Power FC and injectors are now no longer needed.
Grab a good tested package for a reasonable price.
I am asking $1400 FIRM and a cash payment for the full amount is required on pickup
I am located in sydneys western suburbs.
and you can contact me via PM through SAU
or you can sms me on PH#:0433-750-636
Kind regards
Dave
Edited by MR FLWLSS
https://www.sau.com.au/forums/topic/209815-sold-please-delete/
i cant belive theres no intrest in this from anyone in sydney :)
I coulda paid you by now.. but am in qld.. oh well. i'll prob get scammed for the one on boost for $800 new. haha
ive been scamed outa stuff before and its no good thats why i like pick ups and cash exchanges
Your the one selling it though..., shipping will only be about 20 -$30
I would buy this, but I don't think I have $1400...
Plus Western suburbs are too west for me, and I am too lazy :action-smiley-069:
Would you accept a turbo to supplement the price? :) (see sig)
I'll see what I have in my bank account on Friday when I get paid...
lol how do u get scammed as a seller?
buyers risk..
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
