Each airbox & intake is designed for each car seperately to deal with a number of issues.
You can't just say one is better than the other cause it would perform differently on each motor.
as for interechange-ablity I couldn't say, you'd have to see if the AFM's, turbo's and plenum run & connect in the same fashion
wtf a normal response from you? :thumbsup:
I only talk shit when you do :)
yes.
it has a pod.
I need an air box.
someone has offered an R34 box for free.
or I just buy an R33 one for whatever.
so..
free v money = new thread asking questions.
Don't bother with the R34 box.
Buy a 33 airbox. Don't pay more than $50 for it either.
yes.
it has a pod.
I need an air box.
so..
nice! pics?
yeah fair enough question then.. you'd be silly not to take the free airbox and at least see if it fits. its going to flow at least as good as the R33 box if it fits
good luck with it
