I got profec b spec 2.
And I started to notice this clicking sounds. First I thought that its detonation lol. But they were to electrical. Like inj. or relay working.
Everytime I open the throttle 30-50% and getting in the boost zone, I got this clicking sound.
I don't get it with WOT.
Is it normal ? Do you guys have the same thing with Profec b spec 2 ?3
2)
Another thing.
Anyone got a step by step manual for setting up boost with profec b ?
I searched the internet and its a bit confusing. Some use start boost. Some don't use it.
Maybe someone could share his setup ? Like set - %, gain - %, start boost -, warning, limiter ?
I wan't the car to have more punch/mid range. But seem to lack it, when I start playing with the controller.
Edited by robots
A fast clicking noise?
I had this with mine,i think its normal.You should have got an english instruction manual with it.
There is gain and set gain.You use these to set desired boost level and how hard the boost comes on.
They are easy to set,all you need is a mate and a good boost gauge.Dont go by the stock one in the cluster.
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
