hey guys not too sure where i should of asked this so just gonna ask it here. some ppl have told me if ya run ur gtr on rear wheel drive for too long f*ks it up! is this true? cheers
I cant see this being the case. I know if you modify the torque split and put too much to the fronts you can wear out the transfer case but seriously, the GTR's drive RWD most of the time anyhow..
-D
Only R32 GTR's and GTS4's can run in rwd. 33's and 34's will f*k up!
How come? Curious about this. I know you gotta remove the driveshaft for the front wheels if u wanna dyno the 33/34 gtr's but surely that shouldnt cause any long term damage? Wouldn't it just mean that more torque goes thru the gearbox to the tailshaft/diff? Or is it something to do with the transfer case?
Thanks
-Ben
Fuse box in the engine bay it will be one of the green ones.
Look on the lid of the fuse box and it will tell you which one the 4wd is and just pull that one out and then the 4wd light will come on on the dash once you start driving.
33's amd 34's have a 5% preload of torque on the front wheels so when u pull out the fuse for the attessa in 33's and 34's and start do drive off very soon you'll start to see smoke come out underneath of your car because the clutch packs in the frontdrive shaft have been rooted
Hey Vince, you've got me a bit worried there now......so what if I pull the fuse and drop the centre shaft to do a few runs on a 2WD dyno?
Can it cause any probs doing this cos I've already done it on my R34 GTR.
I cant see the logic in this with regards to the R33 and R34's
The R32's are happy to be in 2wd all day long
I have seen shafts pulled out to run there GTR's on the dyno and have never heard of any damage coming from it..
for a while i was running my car in rwd, after a while the the 4wd light turned off and i noticed on the guage that it was still transfering toqure to the front?!?!
i was told that just buy pulling the fuse it can still engage 4wd if the hydrolic pressure builds up. the only way to go fail safe is to drop the shaft...can anyone confirm?
Edited by Turbz_13
I took the fuse out last night, drove the car to and from work and the 4WD light didnt come on, got alittle sideways doing a sharp u-turn so im guessing the 2WD has engaged, might put the fuse back in, just to be safe.
You may have pulled the wrong fuse, just make sure as the are blank spaces between some of the fuses.
If you pulled the correct one you should be able to light the tyres very easily if you have a strong clutch.
hey mate sorry should have been more clear
yeah dropping the front drive shaft/centre shaft and pulling the fuse is fine
its just when u only take out the fuse and leave in the shafts it will fk up :domokun:
hey buddy when u take out the atessa fuse the 4wd light should come up on your dash..its a yellow colour.. i know mine does in my 32 GTS4 and also in my mates 32 GTR
Yeh taken out the right one, taking off can definatly feel its in rwd and the car gets sideways really easily, whereas in awd it was alot harder, also the car doesnt corner as well lol. I'll go out and have a look for the 4wd light. What does taking out the anti-skid one do? anyone know?
its just when u only take out the fuse and leave in the shafts it will fk up :P
Cool, that's what I thought. I was always under the impression that you have to drop shafts on the 33 & 34 GTR's but the 32 GTR's only need to have a fuse pulled fror a dyno run.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
