Nistune Powerfc Hks Fcon Haltech Ems Link Ecu Etc Real Time Road Tune And Dyno Tune Available In Sydney And Other State
Also R34 boosted up under 12psi , it will ping at 3600-4400rpm when the accelerator is put down on street.
Because R34 ignition map is 3600-4400rpm very hi ignition timing for Australia fuel.(maybe 100 octane fuel is OK)
I am finding this with R33 S2, 40th anniversary model. Even on standard boost, it will ping if I run 10psi in midrange RPM.
100RON fuel made a big difference, but I can't get it locally.
Toshi,
Need a tune badly mate.
Car:
R33 Gtst
Mods:
- Walbro in tank fuel pump
- GCG High Flow
- Front Mount Intercooler
- Spark Plugs Gapped .8mm
- 3inch Turbo Back Exhaust
- Boost Controller
- Apexi Pod Shielded
- Cold Air Intake.
Looking for 230+rwkw.
Am I missing anything here?
Please let me know.
Will book in Dyno tune in next month or two.
Cheers!
RJ.
Toshi,
Car:
R33 Gtst
Mods:
- GCG High Flow
- Boost Controller
- Cold Air Intake.
Please let me know.
Cheers!
RJ.
I sent PM.
hi,
can you offer generic tuning for "standard" mods ie r33 running FMIC, stock turbo at 12 psi ,3" exhaust with 98 ron.
Just for those of us who do not live near you, we can post you our ecu and have it corrected?
Like a mines spec ecu- better AF ratios over 10 psi, better boost timings, lose the speed limiter etc.
I know it wont be as hard tuned as the ones that you road/dyno tunes better just better then the standard ones.
Lads,
Had my ECU remapped my Toshi today.
Easily the best $500 bucks ive spent in a long long time. Its a rare event for me when i drive away from something genuinely thinking i got my moneys worth. This time its without question.
Toshi spent much of his sunday tuning my car until i was happy, explained every part of the process clearly and kept me completely involved. The car is absolutely flying and i couldnt be happier. His focused attitude and attention to detail was second to none, this was very apparent especially after dealing with peanut after peanut mechanic (and twice the cash) who obviously had no idea.
I strongly recommend his services to anyone. He clearly knows his stuff, and takes the time to do it properly. Pretty bloody rare (and valuable) in my book. Ill take the car nowhere else.
Thanks again Toshi, we will speak soon about the intercooler etc.
Cheers,
Matt
Thank you Mattw_83.
thank you for asking datsfreak.
Sure I do send generic tuned ecu.
What I usually do is,
Firstly I will ask you for a deposit. ($450 for ecu and $200 for deposit)
Then I'll send you the spare tuned ecu that i have.
After making sure you are happy with the tuning, i will ask you to send me your untuned ecu and i will send you back the $200 deposit.
I did samething for robmbt.(and other many custermer)
http://www.skylinesaustralia.com/forums/Re....html&st=80
hi,
Hi Toshi,
What are the potential problems with the generic tune and would it help if I got a dyno graph with AFRs to send you beforehand?
It'd be better if you go to dyno after you recieve the remaped ecu.
Since I cannot site the condition of your car, fitting chip can be potentionally dangerous at full boost.
So I ask customers to go to dyno straight after recieving the ecu to check ignition timing , AFR, ping, etc is fine.
If there are any problems, I will send you another chip.
Hi Toshi,
I just read what you did for robmbt, he got 200RWKW at 10-11psi from a AUTO.
THATS awesome(its a auto!)! When I get some cash together I will contact you.
Thank you Mattw_83.
  • 4 weeks later...
I can highly recommend this tune, I just got it done last weekend and the difference is amazing.
The car feels really strong and has absolutely no flat spots, it feels like a whole new car.
I am yet to dyno my car to see how much power it is making but it feels very healthy!
Thanks Toshi!
Edited by da spike
hey toshi, got a question similar to "datsfreak", only difference being, my motor is a RB25DE+T (ie, hi-comp turbo motor)
a list of the mods iv done so far is here, along with a few bits that are on the drawing boards (bigger fuel pump, rising rate regulator, bigger exhaust) as you can probly tell, im building it up to be basically a high comp standard RB25DET motor.
http://www.skylinesaustralia.com/forums/Ig...em-t277719.html
basically why im asking is that i live in western victoria, which would be a good 18-20hour trip from sydney (in that time, anything can break, especially on an untuned car)
would it still be possible for me to send you up my ECU and get a remapped one sent down to suit my highcomp motor? would there be any extra cost involved etc...
i have access to a dyno so yeah...have heard nothing but good things about you mate, theres plenty of other tuners down here in vic/sa, but you seem to give the best bang for buck from what i can tell...
hope you can help me :banana:
I can remap.
I remaped his RB25D+T and he got near 180kw.
Also he is living is VIC.
http://www.skylinesaustralia.com/forums/Ad...ml&hl=toshi
Toshi -
Whats it worth if I send you my ECU (R33) to only have the 180k limiter removed and also have the boost/afm cut removed. no tuning or anything needs to be done.
cheers Andrew
Toshi -
cheers Andrew
I sent PM.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
