I am about to replace the turbos on my R33 GTR and i have a choice to make.
I can get R34 N1's through my mechanic for $1495 a piece or i can get GT2860r-7 for $1250 a piece from another retailer.
Which do you think i should go for? I am leaning towards the GT2860's because from what ive read they are the same specs and saving close to $500 is always good.
What are your opinions?
Cheers
https://www.sau.com.au/forums/topic/210168-r34-n1s-or-gt2860r-7s/
Cheers
Hi mate,
I've installed GT2860r-5, a slightly larger turbo than N1 on my R34 GTR. Works very well and got turbos for same price as GT2860r-7. Was considering HKS GTSS but got garretts for much cheaper and works very well with a good tune. Check the prices on -5 as they were the same for -7s when I got them some 4-5 months ago. No compromise on lag and responses very well on pretty much anywhere on rev range...........now supporting 360+ rwkw.
Yes they are brand new for that price, im not risking second hand turbos.
I have looked at the -5's and have considered them but im really not looking for huge power, i dont think i will ever go over 300 at the very most. The main reason for me replacing my current turbos is because my original ones have major oil seal leaks and need replacing, i have been saving the money for new turbos for a while so saving 500 odd is really good for me.
Hi mate,
-5's are 2530 equivs... there is no way they are the same response as factory/-7's/GTSS/R34N1
There most certainly IS a compromise on lag and response compared to the smaller batch
Thats what i was lead to believe.
I am after response over overall power. I am not wanting huge power, i mainly just want my car back on the road :)
I think ill go for the -7's it saves me money and i know they will do the job i want.
There is a black GTR I saw on an igition DVD - which isn't coming to mind right now
but its running N1 turbos on a built motor - 1.7 bar saw it 400kw @ all 4
They upgraded to 2860R turbos (not sure whst specs exactly) now and it makes about 424KW @ all 4
anyways just thought I'd throw that in :whistling:
Hi guys.
I have just done my turbos a couple of months ago on my R32 GTR.
I went for the 2860 -7 with the smaller exhaust housing.
I was told that this was a new smaller housing from Garret to try and reduce lag.
Now, don't shoot me for it because I don't know alot about it.
I know one thing. I was running standard GTR turbos with steel wheels and the difference is huge.
I feel that lag is now non existent which makes it for a real good street car.
I must say that I also installed dump pipes, computer and boost controller so obviously some of the improvements are also due to these extra bits.
Anyway, the car drives really well. The response is quite good.
Power wise, I do realise that power figures varies from place to place but to give you an indication of what was achieved with my current setup, the final power figure on what I believe is a safe tune was 280kw at 1.2 bar.
Anyway, this is my results with I am happy with so I thought that I would share it here.
thats rus's and marks car make 427rwkw on a built gt500 block and tomei internals awsome car i would def go with the 2860s you see nothing but good from them...
Edited by johnbarry88
Turbos ordered :D I went for the -7's mainly for the response etc. I am now a little worried after seeing this thread ( http://www.skylinesaustralia.com/forums/Ga...60-t210071.html ) about my dump pipes. I guess i will find out in a couple of weeks.
Edited by Cooper
thats the one! fkn machine that thing
inspirational video that you should all watch: http://uk.youtube.com/watch?v=TPPUMoDmWlk
running N1 turbos and making 400kw @ 1.7bar
You never asked if he changed cams ,has adjustable pulleys or has an after market computer.
But yes........power output is larger with the 2530's and lag is greater.
If you are not wishing to change anything else on the car except for Turbo's you have made the right choice.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
