Most R drivers have such as massive head they don't even wave to other R skylines let alone V35's
Good point, drove past a guy in a r32 gtr putting shit in his boot just kinda glanced then looked away. Probably didn't realise
Spotted someone in a black coupe driving past heather dale station about 30 mins ago. Had personalized plates
Ha ha ha, the car finally gets spotted and its the mechanics testing out the control arms and new stance! Black rims?
haha yeah had black rims, looks really nice buddy!!
Whoever it was slowed down heaps for the train lines, so at least you know they are looking after your car!
nice, yeah I really trust the Revzone guys.
Just saw a silver V35 near Boxhill with after market headlights, rims and a matt black Nismo trunk, looks great.
Perth - Spotted... 2pm today, caribbean blue V35 coupe parked on side of Williams Street, in front of the Wesley Centre.
Fremantle - Spotted 4pm today, V35 coupe, white with black roof, parking lot behind Kalis
Edited by Holly
Just spotted another silver V35 but sedan! Went through Springvale McDonalds drive thru
Also saw another silver coupe and black coupe parked at glen waverley and a white coupe near Brandon Park shopping centre, damn seeing a lot of v35s today!
Edited by itsRICHARD
Since my car doesn't get spotted in Geelong *sigh* I was hopping to be spotted last night driving through Melbourne. I spotted a silver coupe on Flinders St at like 10:30pm *waves*
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
