Amec Drift Car , First Outting At Archifield This Friday
Well it's all back together and ready to rock , have been hanging to jump back in the seat , speakingof seats , has a brand new Bride low max going in friday.
So come on out and say hello, it's a great night out , and a cheap one at only $10 entry
Stay till the end and have a chance togo for a ride in one of the drift cars , maybe even mine :(
Will post up pics as soon as I have them, hope to see you out there !
