Hi all,
Just after a bit of advice, The car is a GTR R33 Skyline.
The items that are fitted is
N1 Turbos
exhaust - Just fap front pipe, highflow metal cat and cat back Kakimoto Regu 06&R.
Blitz SUS Pods
Trust FMIC
Have bought ready to install....
Greddy profec 2
Tomei Cam gears...
and
Power FC and controller
Standered fuel pump, injectors etc etc
Should i change the fuel pump? or injectors? Will the stock GTR items be ok? If need to be changed what would surfice?
Should i look at adding anything??? I want to do as much as i can before the tune so i know it'll all be right.
Just wondering what COULD be expected from this set up??
Thanks
Edited by Adz2332
You need both before installing the PowerFC or you'll be wasting your time and money tuning it. You'll max out the injectors before making any meaningful power and the workshop will most likely tell you what everyones told you already.
upgrade your fuel system....
Injectors and fuel pump will go to about 270kw - people say 300kw but it never makes it to there as the are old and tired
I would personally go some bigger injectors and also a new fuel pump - NISMO/TOMEI etc
You've come this far so you might as well put everything on at once and get it all tuned together otherwise you would be just wasting money going back later for more boost + injectors & fuel pump
Yes - Although the 040 might require you to modify the cradle to make it fit - had to cut the bottom of the cradle off in my GTST
TOMEI pumps go in way easier - use the stock fittings/mountings etc and come with new seal and shit
Yes - injectors are piss easy in GTR
there is a DIY somewhere as well
Also with the fuel pumps, all the nismo 276L/H, HKS 280L/H Tomei etc etc all around the same price etc So they all around the same??? or are any better than others??
Edited by Adz2332
you might get away with one of those up 350rwkw maybe..yeah yeah I know heaps of ppl are making that on standard pumps blah blah blah...its about how much power you want know and in the end run, sure you can use it as a lift pump in the next upgrade but then that means another tune and more $$$ wasted...just do it rite the first time and be done with it, run new fuel lines like 3/8" lines again ppl say standard is fine but think 3/8" or 10mm is 20% bigger in size than standard...
At the moment greenline has a special on SARD injectors, so i was thinking some 700cc. Will they do the job?? As there the same price as the 660cc ones
Nismo and HKS are better pumps than Tomei. A few ppl have said Tomei's lose voltage at high RPM and the engine leans out.
GET the pump and injectors. As soon as i cranked the boost (from stock to 12psi) the pump started to die.
Pump change is a DIY job, i'm not a mechanic and i got the old pump out easy. Injectors give the DIY sectin a read.
Get injectors that suit what you need from them. No use getting 1,000,000cc's when i.e. 660cc will suffice.
Don't put a junky Bosche 040 in your GTR if you want to make good decent power and reliably.
Get a Nismo 275lph @ 72psi pump. It will fit it like a glove and require no modifications. Oh, and you won't have pickup issues either.
excellent thanks guys thats the info i was after!!
Glad there both a DIY job, will search for the info...
Ill get a price on the nismo 275lph and the sard 700cc injectors. cheers guys.
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
