Was meee, saw ya 2 buddy and ur last second wave....i waved 2 hehehee had a feelin was u and nearly in the same place :)
yea, i live in that area :P and my parents owns that bottleshop on lower dandy:D
I'm confused as to what NZMO actually is. It's an R34 with badges say GTS-R.
WTH??
i bought my front bar off him llol. i remember when he was doing the stuff to his car. pretty sure its a GTT converted to look like a GTR making it a GTS-R or something like that
OIC... makes sense now. That's a pretty good conversion.
Yeah its a conversion(Top Secret GTR front bar and Z-Tune GTR Bonnet) front diffuser ready to go on , thanks for compliment,you took a nice photo of it, i used it for my desktop.
cheers,
David
spotted Nick gtstsedan in his undies outside his gfs house this morning
geez man, wear a ROBE
lol the chiks dig it :laugh:
Finally after five years i've been spotted. Nick it's actually dark blue, but green's cool too. I was getting some motul and bits and pieces. :thumbsup:
ahk
yeh i was to :laugh:
you from around the area?
CNBLOW at the keilor village pub (great pub)
Spotted you as well Paul, i was actually across the road at the park for a birthday. While i was there spotted a grey kitted 32 with black TE37 wheels? gees it was loud!!, it had a writing which said 73 on the windscreen, possibly from the drags? for some reason i think it was "Roy"'s car, but could be wrong
spotted a silver R33 GTR with a carbon hood and SAU stickers
also spotted a tuff R33 GTR with no wing on the great ocean road
went past a workshop that had a heap of GTRs, stageas, anything with an RB. the OH R34 gtr was there too
Edited by GTR-boy
sounds like OH Performance on McIntyre (sp?) rd in Sunshine
the purple one? thats a gtt with a rb26 its not a gtr
looks like they've taken over that nismo joint next door aswell...?
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
