Running 12lb boost, LT12 computer - just over 303hp at the wheels !! ;) I am very happy with that.
It is a GTS-t. My mechanic installed an air temp sensor today and change the adjustable cam gear. Went from 264.3rwhp to 303.1 rwhp with just those changes.
It is idling a bit high though. Do the new microtechs cause the car to idle higher than the stock computer? I am idling at about 1000->1200rpm !! I am going to speak to bloke tomorrow.
https://www.sau.com.au/forums/topic/21055-just-had-my-r33-dynod-today/
I am currently running a 500hp Garret Ball raced Turbo. (but at only 12lb boost)
The only other mods I have are...
Large Front Mount intercooler
LT12 Microtech
Variable cam gear
descent exhaust (but nothing spectacular)
custom dump pipe
Iridium sparks
carbon clean (everyone who gets a carbon clean gains about 5rwkw)
good tune !
Hmm, that turbo's just a tad bigger than mine. The biggest difference between your car and mine is the ECU and the cam gear. I think the cam gear has to be the next mod for mine because I can't afford a new ECU :)
carbon clean? where can you get one of these guys done!? :)
yeah, boost is what its ALL about....and cam gears too..hrm! i think im doing okay for the mods i have then.
186rwkw
powerfc
apexi avcr @ 1bar
full exhaust
front mount
stocky turbo...
next mods will be fuel pump, clutch & turbo of some description!
I place in Toowoomba has a carbon clean.
My mates '86 Brock Commodore got 5rwkw. Another guy's skyline got 6rwkw. I don't know what I got as mine was done when I got the new turbo/sparks etc.
186rwkw if pretty damn good for those mods. Youy must have a good tuner as well.
Nice results gjb977 !!
Tell me more about this Carbon Clean..
Whats it do?
Where does it go?
How much does it cost?
What does an Ex Cam Gear cost to be installed and tuned (roughly) ? They are quite a cheap mod it seems:
Apexi: $142
HKS: $153
OS Giken: $293
Tomei: $199
Trust: $171
I love these cheap mods with slight power increases, the type of mods that many people skip and jump straight in for the big turbo's etc. (JimX maybe we could order 2 cam gears and have em installed/tuned at the same time/place)
I'm currently at 272 rwhp and confident that with some small mods ($$) I can crack 280 rwhp from my basic setup.
Hey Frankie not bad power for the mods you have :)
I'll get the info re the carbon clean from my mechanic (more like an engineers workshop) and post the info tomorrow. All I know is the solution so that expensive he keeps it in a safe.
He's done so many qick cars it's not funny. (including a 9.6sec Cortina) (mainly does commodores though)
he made the adj cam gear out of my stock gear. (only had one done) - this is alot cheaper than buying 'name' brand ones.
Interesting... do you know the costs involved to get this done?
The HKS has come down in price by 25% in the last 3mths which I have had my eye on and is looking pretty nice at this stage (both price wise and physically looking).
did ur power fc have much to do with the power??
cos i am looking at getting mine on the dino, with a 12psi full exhaust, front mount and cold air on its way..
but i was looking at a power fc, are they the way to go or not??
cheers
this is a before and after. only difference being boost was raised from say 0.7bar to 1.0bar.
its hard to say what difference the powerfc made on top of the boost gain, but when I first installed the FC i remember the torque was raised like 50newtons across the whole rev range.
the car definately felt alot more torquey down low. up top there wasn't that much difference, maybe just under 10rwkw gain?
but it all comes down to the tuner. its hard to go past the FC because of its plug & play features and sydney workshops/tuners are getting alot better at them now (c&v for instance). so there'll be an abundance of knowledge around...
I'm not quite sure the difference between your car and benm's but shouldn't you be getting more the same kw's as benm. You are nice and lean so what do you think the diiference is as the HPI R34 has also 1 bar and 202rwkw's, i ask as i am about to get my car tuned and expect to get nealy 200rwkw?
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
